Old 05-15-2015, 07:29 AM   #1
Braveheart
what's involved in switching my T350 to a T400 in my 71 K5?
Anyone no what is involved in switching my T350 to a T400 Tranny in my 71?
I thought i saw a thread on this but cant seem to locate it. Thanks.
Braveheart is offline   Reply With Quote
Old 05-15-2015, 09:59 AM   #2
praisegeetarman
Re: what's involved in switching my T350 to a T400 in my 71 K5?
Special tail shaft for the T400, move the transfer case back, longer front drive line, shorter rear drive line, add electric kickdown switch. That should be it.
hope this helps,
Keith
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find)
67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find)
Keith Riel
praisegeetarman is offline   Reply With Quote
Old 05-16-2015, 07:55 PM   #3
Braveheart
big help thanks. where do i get the special tail shaft?
Old 05-16-2015, 10:56 PM   #4
praisegeetarman
Here is the adapter kit.
http://www.advanceadapters.com/produ...50adapter-kit/
Spendy, but the turbo 400 is bullet proof. A well built turbo 350 will do for light four wheeling.
Keith Riel
Old 05-18-2015, 06:57 AM   #5
Braveheart
Thanks for that link! It says a TH350 coupler is also needed but i don't see that listed.
I put a 500+ HP 496 in my K5 and even with a built TH350 it can't take it. I think it's worth the $$ to go with the TH400. will save allot of headaches and down time. As far as being "spendy" I'm so deep into this truck already it doesn't matter
Old 05-18-2015, 02:34 PM   #6
GMC-YA68
GMC-YA68's Avatar
You can buy a built 2004-r from Monster and you wouldn't have to buy new front or rear driveshafts, or move your t-case.
http://www.monstertransmission.com/2...l#.VVowWvlVhBc
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 05-18-2015, 04:01 PM   #7
praisegeetarman
If you have a TH350 in there now you already have the coupler.
Good luck with your project.
Keith
Keith Riel
Old 05-20-2015, 06:37 AM   #8
Braveheart
thanks for this info. the "monster" tranny seems like the way to go
Old 05-21-2015, 10:50 AM   #9
Blazerowner
Blazerowner's Avatar
You can move the engine forward as well. I've seen many go this route rather than moving the transfer case. Keeps your drive lines in the same place as well as your shifter.
Kirk
72 Blazer CST 4wd highlander
66 Nova
Blazerowner is online now   Reply With Quote
Old 05-26-2015, 12:08 PM   #10
PGG
I like the idea of swapping to an overdrive tranny. I can barely run 70 mph on the freeway and it would help mileage too I guess. I might wait until I need the engine rebuilt but this is my thought for the future on mine.
That link to Monster shows a suggestion to the 700R for high horsepower engines.
What would a 305-700R swap take?
Do yall think it would lower the value much of a fully original 1972 CST like I have?
I guess I could always save the 350 for later in case I ever sell it.
Thanks PG
PGG is offline   Reply With Quote
Old 05-27-2015, 02:55 PM   #11
Blazerowner
I wouldn't think it would affect the value because you don't modify anything other than moving the engine forward. The frame actually has the holes to do this so as far as I can tell there is no drilling. I was considering the swap but I have a rebuilt th350 and don't do much highway driving so I wasn't as concerned. Also have 3.08 gears so 65 isn't that bad.
Kirk
66 Nova
