Old 05-25-2015, 12:32 PM   #1
jadedbird
jadedbird's Avatar
2000 s10 4.3 gas tank in a 64 swb?
Any body used this? I have seen where people use 94 tanks. And they look nearly the same.
I plan on running a 5.3 motor, in line walbro 225 and corvette filter.
I'm just wondering if the sending unit is good to use? Also does anyone have a parts list for everything to get a s10 tank to work?
jadedbird is offline   Reply With Quote
Old 05-26-2015, 01:29 PM   #2
ob1monkey
Re: 2000 s10 4.3 gas tank in a 64 swb?
you wont find much on here regarding that tank and sending unit. before i put in the truck you saw i did extensive research. so far i am the only one i have found to use that tank and sending unit. they make an fittings to convert to a standard line. the biggest reason i used that tank was due to the bucket around the pump. which solved all my fuel starvation issues with an external pump.
ob1monkey is offline   Reply With Quote
