Old 06-01-2015, 03:30 PM   #1
Classic v6 GMC's
Classic v6 GMC's's Avatar
1960 Chevy Truck "Viking 10"
Update and new plans:
We just got a 63 c60 that is nearly rust free so we are going to use most of the sheet metal except for the hood and grill. We are going to use the short bed and all the custom trim. The drive train will consist of a 1977 Chevy frame that was completely rebuilt and lowered. The wheels on the frame right now are 15"x7" on the front and 15"x12" on the rear but that is going to change. The engine is a built 454. The transmission is a rebuilt th400.
Check post #19 for pics of c60
Classic v6 GMC's is offline   Reply With Quote
Old 06-01-2015, 03:58 PM   #2
1963c-10
1963c-10's Avatar
Re: 1960 Chevy Truck "stock looking hot rod"
Welcome and very cool project you have planned.
Do you already have the original trim? It can be elusive to find.
Looking forward to updates on the build!!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-01-2015, 04:05 PM   #3
Classic v6 GMC's
Yep we got the trim. We just have to find the grill and a v8 hood emblem.
Old 06-01-2015, 04:18 PM   #4
1963c-10
1963c-10's Avatar
Very cool. I'm in the process of two builds (63's stepside and fleetside) and will be using the 1960 trim on my fleetside also. By far one of the hardest things I had to source for either build.
I did put a complete set of the back cab trim together for both trucks and have a almost complete set of trim for my fleetside. Just need one more door piece is needed at this point.
I like the resto mod theme as its what I like also. Stock look and plenty of upgrades under the hood for safety and speed of course!!!
Old 06-01-2015, 04:20 PM   #5
1963c-10
1963c-10's Avatar
The v8 emblems and grills do pop up from time to time. Just saw a 6 cyl bowtie on ebay the other day, which they don't pop up that often either.
Might not hurt to post a want to buy in the classifieds here also.
Old 06-01-2015, 09:37 PM   #6
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Very cool build. Awesome to see a 454 going in there as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-01-2015, 09:54 PM   #7
Ta2Don
Ta2Don's Avatar
Big Block!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 06-01-2015, 10:38 PM   #8
rwade
rwade's Avatar
I'm in for this one
Wade
rwade is offline   Reply With Quote
Old 06-02-2015, 11:09 AM   #9
Jeff La
Waiting for more
Jeff La is offline   Reply With Quote
Old 10-11-2015, 10:16 PM   #10
Classic v6 GMC's
Been a while so here is an update. We picked up a parts truck with a cab in a lot better shape a while back. It just needs rockers and a small floor repair. It is a gmc cab with a small window so we had to remove the small window panel and dash. Then we removed the chevy dash and big window panel from the other cab. After that we sand blasted and epoxy primed it. Pics to follow.
Old 10-11-2015, 10:25 PM   #11
Classic v6 GMC's
Cab Pics
Old 10-11-2015, 11:37 PM   #12
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
More quick work! lol
Old 10-12-2015, 12:50 AM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
cab is interesting.. what was it off of? I see a 62-63 heater hole, and the inboard 63 style front cab mounts, but it is still set up for the hydraulic clutch like the early trucks?
regardless of that looks like a great cab to start with.
have you researched how these trucks fit on the 73-87 frame?
captain fab suggests against it because you get the equivalent of about a 4 inch body lift in order to clear the rear cross member.
however there was one member that did a build on a 73-87 suburban frame that came out ok, I don't think he was going for a lowered look though.
interesting to see how this turns out. I love the look of the gold and white with the custom trim.
Old 10-12-2015, 10:31 AM   #14
Classic v6 GMC's
It was actually done a couple weeks ago but defiantly been busy.
Old 10-12-2015, 10:47 AM   #15
Classic v6 GMC's
It is a 63 cab. I thought the hydraulic clutch was unusual also. It was an auto truck so it had a plug in the hole. I have read about the body lift but the frame was already lowered so that will compensate for most of it. The only reason for using the frame is that is already done.
I like the gold and white as well and will be one of the few with the combo.
Old 11-16-2015, 06:59 PM   #16
Classic v6 GMC's
Not much progress yet but did find a hood ornament.
Old 11-16-2015, 09:00 PM   #17
jonzcustomshop
1961 crewcab
what did that set you back? I haven't been able to find one for less than $250!!!
I am currently hoping to find a whole truck with the ornament for 2X that I keep looking c/l hoping a v8 60 series will turn up cheap.
Old 11-16-2015, 11:15 PM   #18
Classic v6 GMC's
I've been looking for a while to and finally came across a school bus on craigslist. He wanted to sell the whole bus but when we offered $100 for the emblem he took it.
Old 02-13-2016, 11:32 PM   #19
Classic v6 GMC's
Re: 1960 Chevy Truck "Viking 10"
We just this 63 c60 that is nearly rust free so we are going to use most of the sheet metal except for the hood and grill. We are going to use the short bed and and all the custom trim. The drive train will consist of a 1977 Chevy frame that was completely rebuilt and lowered. The wheels on the frame are 15"x7" front and 15"x12" but that is going to change. The engine is a built 454. The transmission is a rebuilt th400.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Old 02-13-2016, 11:46 PM   #20
Classic v6 GMC's
Today we got busy and got everything disconnected and the body off the frame.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 02-14-2016, 07:03 AM   #21
chad64chevy
chad64chevy's Avatar
what size tires are on the 15x7 an 15x12 rims? I have the same size rims just the silver rally color! my 15x12's have 4.5" back spacing
chad64chevy is offline   Reply With Quote
Old 02-14-2016, 07:35 AM   #22
darkhorse970
darkhorse970's Avatar
Nice project! I like your plans.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 02-14-2016, 08:22 PM   #23
Classic v6 GMC's
I think the 15x7's are 235 60 r15 and the 15x12's are 295 50 r15. That's cool. I'm not sure what backspacing ours are.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 02-14-2016, 08:24 PM   #24
Classic v6 GMC's
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
Old 02-14-2016, 08:31 PM   #25
Classic v6 GMC's
Got the cab sitting on the frame.
1966 GMC Long Step
1960 GMC Custom
1962 K20 Tow truck
