Old 06-18-2015, 09:57 AM   #1
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Suburban Exhaust Pics - Lets see them!
Hey folks, Looking for idea's for my 72 Sub's exhaust.
I did what I could to connect the LS to the existing pipes, but the PO had the pipes ran and they run low and exit rear, and don't care for the look.
I'm looking to run a pair of magnaflow hi flow cats and a pair of 14" magnaflow mufflers. Thinking side exit.
Like to see some pics of what you all have, on the rack shots, rear shots, side shots... PIPES... lets see'm
bowtieguy79 is offline   Reply With Quote
Old 06-18-2015, 10:25 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Suburban Exhaust Pics - Lets see them!
Do you need the cats or do you want the cats?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 06-18-2015, 10:35 AM   #3
bowtieguy79
Ephesians 2:8
I want the cats. Family rig, keep the fuel smell down and take a little drone out of it at highway speeds.
Old 06-18-2015, 07:22 PM   #4
72MARIO
72MARIO's Avatar
Same here. I am looking at redoing mine this July. I am considering a single 3" with a cat and magnaflow muffler to keep the noise down. its really hard to consider a single exhaust but it will sure keep the cost lower. I doubt there is really much vs a crush bent dual system.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-22-2015, 05:46 PM   #5
Advanced Design
Advanced Design's Avatar
My Burb has a single pipe and muffler on each side with the side exhaust outlet. Don't really like the look or sound.
What I would like to do is install a system with a cross over like I have on the 56 Chevy and use a rear exhaust exit. I have been very happy with the performance, sound level and lack of drone on the Pypes exhaust.
Advanced Design is offline   Reply With Quote
Old 06-22-2015, 05:50 PM   #6
Advanced Design
Exhaust exit in front of rear tire.
Old 06-23-2015, 05:30 PM   #7
vectorit
What?
vectorit's Avatar
Mine is a ramhorn manifold dual system with H pipe exiting rear of the back wheels.
The mufflers are Flowmaster series 70's.
I want to go to an OE design single system with a large quiet muffler some day, since I am tired of the system I have now due to drone and cabin noise.
I keep my suburban stock for the most part, so this just takes me in the direction I have always gone in my restoration.
I do like the idea of a cat, since that would help with the fuel smell.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-28-2015, 08:32 AM   #8
Advanced Design
Brad,
Here is another idea though I don't yet know if it will work on a Suburban.
http://www.flowmastermufflers.com/?p...=17654&x=0&y=0
Old 06-28-2015, 11:50 AM   #9
engairuph
I have a full dual exhaust with Ls3 manifolds with 2 1/2" pipe Borlas mufflers and out behind the rear tires with 2 1/2" pipe.
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 06-28-2015, 09:23 PM   #10
Burbnewb
Has anyone ever been able to compare, all else being equal, the sound of rear-exit over behind-the -wheel? I would want to go for a performance system with quiet-ish cruising.
Dwight
Burbnewb is offline   Reply With Quote
Old 07-17-2015, 06:23 PM   #11
Jbsweezy
Jbsweezy's Avatar
Did you guys just go to an exhaust shop and have them custom build a setup? I just ask because Noone has said a specific system.
Jbsweezy is offline   Reply With Quote
Old 07-17-2015, 06:43 PM   #12
engairuph
I already had mufflers and cut-outs and had exhaust shop do the rest with my specs and location of everything including the length of tail pipes. This is number 4 suburban for me.
Go to the websites and listen to there mufflers and setups and then go to u-tube and listen some others that have setup theirs. Then you will know what you are looking for and cheaper buying your own mufflers and manifolds or headers and let the exhaust shop put it together and custom make the pipe for the vehicle.
Ralph L. Jasper
13 GMC Ext cab
MAI
Interior shop
Old 07-18-2015, 12:36 AM   #13
vectorit
What?
vectorit's Avatar
I've always had the local muffler shop make my systems.
That being said, the system in my burb was done by a local shop.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 07-18-2015, 02:18 PM   #14
Dburger
Dburger's Avatar
My '72 "GMC" has a Magnaflow on it. If I had seen this thread earlier, I would've gotten a better picture:
New Suburban by FordTorino73, on Flickr
Edit: My '72 Chevy also has a dual exhuast, don't know what kind it is though.
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab
1958 Suburban Carryall 3116 ex school bus
1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT
1967 C10 fleetside LWB, 1969 Chevy Suburban C10
1972 GMC Suburban C10
1972 Chevy Suburban C10 clam shell/tailgate
Dburger is offline   Reply With Quote
Old 07-23-2015, 09:37 AM   #15
Gobuffalo
Gobuffalo's Avatar
Some pics of my 70 4X4 with 3" stainless and Magnaflow
Gobuffalo is offline   Reply With Quote
Old 07-23-2015, 01:34 PM   #16
Advanced Design
Looks good Gobuffalo, is that a kit or a you trim and fit?
Old 07-24-2015, 08:21 PM   #17
Gobuffalo
Gobuffalo's Avatar
The cheapest way to go is buy the Flowmaster 3" U-weld kit. I needed to buy 1 extra 45* to finish the tail pipes. The Flowmaster kit is 409 stainless just like the mufflers.
Old 07-24-2015, 09:46 PM   #18
bowtieguy79
Ephesians 2:8
That looks really good. Did you use a tig on the ss?
Old 07-26-2015, 11:29 AM   #19
Gobuffalo
Gobuffalo's Avatar
TIG. the hard part was finding 409 rod. Had to buy a 10 lb. box. Anyone want any?
Also I could not find 3" collector flanges in 409 stainless. I used mild steel which requires a special rod called 309L to weld to stainless.
Old 08-23-2015, 11:09 PM   #20
magicoolbus
magicoolbus's Avatar
I liked the notched bumper set up on some of the newer trucks and knew that LMC now carried something like that, but didn't want to buy a new bumper when mine was just fine. So I cut out some semi circles and re bent my exhaust and added some 3 inch tips.
JB from AZ
1969 Chevy Sub K10
1957 Chevy 3200
1962 VW Beetle
1957 Willys CJ5
magicoolbus is offline   Reply With Quote
Old 08-24-2015, 01:40 AM   #21
53burb
53burb's Avatar
Very NICE!!
53burb is offline   Reply With Quote
