06-22-2015, 12:58 PM | #1 |
No Clutch
Pulled the motor in my C10 to fix leaks and replace clutch. We cranked yesterday (Sounds great!!), but we do not have a clutch at all. When I push in the clutch pedal it feels like I am only pushing against the clutch pedal return spring. It grinds when trying to put it in gear, and will not go in gear. I only tried reverse - was afraid I might run through the back of the shop! The clutch rod is adjusted to its maximum length. The clutch was working before I pulled the motor - just figured i would replace since the motor was coming out. The clutch was last replaced in 1994.
What could I have done wrong? What can I look for without pulling transmission? Or am I just putting off something I am going to have to do? The photo below is from my Haynes manual. Is the clutch disk orientated the right way? |
06-22-2015, 01:04 PM | #2 |
Re: No Clutch
It sounds like the throwout bearing is in backwards to me...
06-22-2015, 01:23 PM | #3 |
The Older Generation
Re: No Clutch
Did you use the same style of pressure plate as you took out? LockDoc
06-22-2015, 01:38 PM | #4 | |
Re: No Clutch
06-22-2015, 01:42 PM | #5 |
Re: No Clutch
06-22-2015, 02:53 PM | #6 |
Re: No Clutch
Yes the larger turning surface toward the motor side. Can you see up in there to judge what's going on with the inspection cover off on the bottom? if the fingers are depressing then the pressure plate is junk. otherwise some dimension has changed to make it so your not getting enough throw. was the throw-out bearing changed too? If so are you sure that height was the same?
06-22-2015, 04:05 PM | #7 |
Re: No Clutch
Did you replace the throw-out bearing? They have a couple of different heights of throw-out bearings It may be a long shot but can happen. If not can the adjustment be changed.
06-22-2015, 04:24 PM | #8 | |
Re: No Clutch
06-22-2015, 04:26 PM | #9 |
Re: No Clutch
I will climb under tonight to see if I can see anything, covers are off - not sure if I can get a pic...
06-22-2015, 07:26 PM | #10 |
Re: No Clutch
did you cut the flywheel the different thickness throw out bearings are for when the flywheel gets thinner there has been times I had to make a new adjuster rod . it really sounds like it is out of adjustment if something with the clutch plate was backward you would not be able to bolt it together the throwout bearing will usually only go one way . I have seen bad pressure plate right out of the box .
06-23-2015, 09:15 PM | #11 |
Re: No Clutch
any updates? very curious about this one.
06-23-2015, 10:38 PM | #12 | |
Re: No Clutch
06-23-2015, 11:01 PM | #13 |
Re: No Clutch
Not a lot of update just a photo of the throw out bearing. Kinda hard to get a decent pic. I will get under the truck tomorrow or Thursday evening and have someone push the clutch pedal so I can watch the bearing. Question: with the clutch released (pedal not pushed in) should the throw out bearing be touching the pressure plate fingers?
06-24-2015, 01:43 PM | #14 |
Re: No Clutch
You said you pulled the motor. To do so, you had to disconnect the bellcrank at least on the engine side. Is your bellcrank properly re-mounted? If it is loose on one or both ends, the clutch fork will not be depressed properly, the tranny will not go into gear, and the only resistance you will fee is the pedal return spring.
06-24-2015, 02:50 PM | #15 |
Re: No Clutch
I had the same problem on a 67 with a 3 speed. I hate to give you the bad news, but you more than likely have the clutch fork retaining clip in backwards or not fully seated on the ball stud. The clip has a curve to it and needs to be seated correctly to allow the clutch to be positioned correctly. I had to remove the trans again and the bellhousing to get it right. You'll know fairly quick if it's right, you should about 3/8"-1/2" free play in the peddle and about 1" of threads past the nut on the zbar.
06-24-2015, 11:19 PM | #16 | |
Re: No Clutch
06-24-2015, 11:21 PM | #17 | |
Re: No Clutch
06-25-2015, 08:09 AM | #18 |
Re: No Clutch
There is a recessed slot milled around the hole the clip rides in, and the curve goes toward the hole. I would strongly recommend you pull it all, then assemble the bellhousing, clutch fork, retaining clip, and clutch fork boot all together. One last thing, you should get a firm "pop" when the clutch fork is seated on the ball, if not, then it's not installed correct or the clip has lost it strength. You can still get them from GM.
06-25-2015, 10:05 AM | #19 | |
Re: No Clutch
Friday night I will prep to pull and will pull Saturday morning when my son can help. |
06-25-2015, 11:14 AM | #20 |
Re: No Clutch
I think I gave you some incorrect info on the clutch free play. You need about 1"-1.5" travel in the pedal to be correct. That should put the clutch release toward the top of the pedal travel, but it can be fine tuned. I would also recommend you change the linkage bushings at the trans, and column while your doing all this. It will shift like butter after all that for an extra $10-$15.
06-28-2015, 03:34 PM | #21 |
Re: No Clutch
I think my next step in troubleshooting my problem may be striking a match
Still no clutch. This is what I did: I pulled the transmission and clutch assembly. I matched up the old throwout bearing to the new, they are the same diameter and same height. The clutch disk was installed the correct direction, it even has a label "this side toward flywheel". I checked the spring that holds the clutch fork to the ball stud in the bell housing. The fork is firmly clipped to the ball stud. When you push the clutch in the clutch rod moves the clutch fork (measured where the rod goes through the fork) 1-1/4 inches. If it matters, my clutch rod is about 9-1/2 inches long, looks like a 3/8 rod. Could I have gotten a bum pressure plate? It was a Zoom Any ideas would be greatly appreciated. |
06-28-2015, 03:58 PM | #22 |
Re: No Clutch
Did you put # 3 in the pic back on the pushrod? And if so, can someone lay under the truck and watch what happens when the clutch pedal is depressed?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
06-28-2015, 04:05 PM | #23 |
Re: No Clutch
your missing the little fork piece on teh end of the rod number 3 in the picture above that will take out the 1/2 of play you have thats causing your clutch not to work.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-28-2015, 05:05 PM | #24 |
Re: No Clutch
Yeah, you're missing the nut (3) at the end of the push rod. Also, you have the wrong style of spring clips (7) on the push rods at the crossshaft.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-28-2015, 11:19 PM | #25 |
Re: No Clutch
subscribed . would be interested in final solution . good luck .
This is MY rifle.There are many others like it but this one is MINE. Beware the man who only owns 1 rifle , he probably knows how to use it. |
