Old 06-22-2015, 08:39 PM   #1
GoaterAz
GoaterAz's Avatar
Simple Question - Brake Line Chassis Fitting
I purchased Wilwood Flexline 220-11372 to pair up with my Wilwood D52 calipers. I opened an existing hole in the frame to 5/8" for the chassis fitting to go through and it doesn't look like I will be able to fit the clip onto the fitting to secure it.
Do you think it will work if I just pound that clip in? (It doesn't look like it will but I'm not sure if these are suppose to bend etc)
I was also thinking about taking a cutoff wheel and 'thinning' the frame around the hole (inboard side).
Any thoughts or guidance is appreciated, Thanks!
Here is an outboard picture just for routing reference:
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 06-22-2015, 09:10 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Simple Question - Brake Line Chassis Fitting
A correct size snap ring might be your answer
Keith
Convert to disc brakes.
Old 06-22-2015, 10:02 PM   #3
Ruscal
Maybe you could chuck the fitting in the lathe and remove a little material from the face of the hex, exposing more groove. That would be preferable to thinning the frame. Also, a circlip is thinner than the deformed fork type keeper, which may buy you some space. You can also "tune up" those fork style clips with a BFM to flatten the ramps so they enter the slots.
Russ
Ruscal is offline   Reply With Quote
Old 06-22-2015, 11:22 PM   #4
swamp rat
swamp rat's Avatar
grab a 2" bantem motor and debur the hole for sure. The clips are avalable at local auro parts stores go get a couple and try and flatten one with a hammer till almost flat and see if it will work. Another option instead of a snap ring would be an E-clip if you can find the correct size.
https://www.fastenal.com/products/fa...E-Clips%22%7C~
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-23-2015, 08:47 AM   #5
cdowns
cdowns's Avatar
me i'd check out the thru chassis fittings from speedway motors they are secured both sides by nuts
Old 06-24-2015, 08:59 PM   #6
GoaterAz
GoaterAz's Avatar
I really appreciate the help here, all great ideas. I learn something new with each task.
I went to Napa and they had Snap Ring, E-Clip #1012 and they ended up working perfectly.
I am happy with the length of the flex line (16"), the Porterbuilt Arms are Standard Length for anyone going through the same.
Me neither.
Old 06-25-2015, 03:12 AM   #7
swamp rat
swamp rat's Avatar
Bingo, glad ya got it figured out!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
