chevy parts
More stuff, not year specific.
for small block chevy: 62 chevy power steering pump crank pulleys water pump pulleys flywheels flex plates clutches clutch cores 327 engine with iron, bolt hole, fuelie heads(so you can bolt on air conditioning), 041 castings, hardened seats 202-160. screw in studs, machined for perfect circle seals 86 corvette 350 long block one piece seal 58,000 miles, corvette low clearance pan, 86 iron heads. New Summit cam, timing gears one piece pan gasket new head gaskets 71 chevy 350 4 bolt main, 2 piece seal, 3000 miles, 92 firebird heads , Edelbrock intake, 2 piece timing cover, aluminum Edelbrock water pump, mild cam, runs good 56 chevy 265 long block, power pack heads, no pan or intake .060 over, needs to be re-ringed only because it has been sitting. no ridge in cylinders. hillenger512@cox.net 602-510-2519
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 07-04-2015 at 05:37 PM. |
Tags |
chevy small block 350 |
