07-07-2015, 05:14 PM | #1 |
Did 86 silverado come with 305 and 700R4??
I thought they came with 5.7 and 3 speed automatic's. Am i wrong? thanks.
07-07-2015, 05:17 PM | #2 |
Re: Did 86 silverado come with 305 and 700R4??
A C10 in 86 would have come with a 305. I am not sure if 350 cubes were available in half ton at that point. 700R4 was available but I'm not sure if a TH350 was (3 spd auto)
1982 K10 SWB 1987 V20 - Sold - Doh! |
07-07-2015, 05:40 PM | #3 |
The TH350 ended production in 1979. The 1980-1986 transmission was a TH350C which had a lock up torque converter.
07-07-2015, 06:01 PM | #4 | |
I thought the 700 came out in 87 for the squares..?? |
07-07-2015, 06:22 PM | #5 | |
Posted via Mobile Device |
07-07-2015, 06:59 PM | #6 |
My 86 Silverado has just that package. 305/700R4. I thought it has a V6 when I took it for a test drive before I bought it because of the lack of power.
07-07-2015, 07:03 PM | #7 |
I'm not 100%, but I think a 350 wasn't available in a 81-86 C10. Only 6 cylinders and 305 V8. Some 82-87 C10's had 700r4 and some THM350c.
07-07-2015, 07:13 PM | #8 |
I believe the 350 was dropped from the half tons in the square body except some of early California models. I don't think ESC passed pollution standards there.
07-07-2015, 09:20 PM | #9 |
Mine was a 305/700r4 and it had just as much power and spunk as it does now with a 350.
07-07-2015, 11:24 PM | #10 |
If I am reading the docs correctly from the GM Heritage center for the 1/2 ton there was a single 350 (LS9) option mated with a 700R4 (MX0) for California only. Only 2.73 and 3.08 gears were available with that option.
305 (LE9) was available with 700R4 (MX0) Non-Cali with either 2.73, 3.08 or 3.42 axle ratio. This was also available in Cali but lost the 3.42 gear option.
'86 Chevy K10 SWB Custom Deluxe 4x4 '94 Chevy Corvette '07 Ford Mustang '08 Lexus LS 460 |
07-08-2015, 02:35 AM | #11 |
1982 the 700r4 came in the 1/2 ton and 3/4 ton trucks 2wd and 4x4.The turbo 350 was used 73-81 1/2 ton and some 3/4 ton.The 305 was used 81-87.
07-08-2015, 12:01 PM | #12 |
My 1985 Silverado came stock with a 305 and the TH350 tranny. Bought in Ga.
07-08-2015, 12:38 PM | #13 |
The stock transmission in a 1985 Siverado if it was a 3 speed automatic would have been a TH350C not a TH350. The TH350 was not produced after 1979. The TH350C has a lockup torque converter and the transmission and converter are not interchangable between the two.
07-08-2015, 01:28 PM | #14 |
simple answere is, Silverado's were only available with a 305 (5.0), the 700r4 was a upgrade option to the th350
07-08-2015, 05:34 PM | #15 |
Same here - 1985 with a 305/700r4
Thanks, Edgar Red 1985 C10 Stepside 350/700R4 2014 GMC Sierra Denali 6.2 2015 GMC Sierra 5.3 |
07-09-2015, 10:22 AM | #16 |
Can Confirm - 1982 305/TH350C
Later Swapped for a 350 Crate. The 350 was installed in all California bound trucks however if they were normally meant to have a 305. |
07-09-2015, 03:26 PM | #17 |
Cruzzzn' Vet
My 83 Silverado has the 305/700R4 factory setup, for being a boat anchor the little 305 still runs great
07-10-2015, 09:21 AM | #18 |
My 86 before the one now was a C10 short box. 305,4bbl, 700r4 and it did run good. Better after a few small upgrades. I miss it.
KA
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
07-10-2015, 03:11 PM | #19 |
I also have an 86 short box that was originally a 305, 700r4, 3.42, G80 (gov-bomb) combo. Heavy duty springs, so it rides like a rock lol. Barebones otherwise....
86 Burb, 5/7 drop, 18" rims, big stereo, work in progress, as well as daily driver. 86 Short box just starting the build. 86 GMC 1500 2wd, ugly blue farm looking truck with a mild 454... More to come! 98 Cheyenne Ext cab short box 2wd. Driver and maybe future project. |
08-16-2019, 10:41 PM | #20 |
08-17-2019, 12:01 AM | #21 |
My 85 k5 silverado i bought in 87 had the 305 / 700r4 combo . The 700 was junk in those yrs and it only lasted about 70k miles. The q78 buckshots didnt help though
88 3+3 454 400 205 410 drw to srw still in pieces 90 3+3 350 400 205 410 srw 84 1/2 ton lb 6.2 4x4 parts truck |
08-17-2019, 09:52 AM | #22 |
I bought my 82,K-10 new.It came with a 305/700-r-4 trans.
I could not buy one with a 350 engine. Was told I had to buy a C/K-20 truck to get it. Mike. |
08-17-2019, 08:42 PM | #23 |
My 86 Chevy had a 700r and a 350 cid engine. I’ve been told that 350 cid was available in Canada. My 89 Gmc also had a 350 cid and 700 trans.
08-18-2019, 12:28 AM | #24 |
I'm never one of those guys to blather on old, resurrected threads about how old it is if it's relevant. However, on this one, I think the original poster got his question answered about 4 years ago. But y'all are welcome to keep adding to the info in the thread.
08-18-2019, 07:46 PM | #25 |
87 came back with fuel injected 350 in half tons
