07-12-2015, 11:41 AM | #1 |
WTS OEM 12 bolt differential cover
I have this OEM cover that has surface rust on the outside and clean inside I removed recently from a 1968 c-10 truck, the outer tip was slightly bent somehow but it does not affect the seal or functionality. See photos. $20 plus the ride. I can throw in the 12 bolts with it. LMK.
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" Last edited by Jake1971; 08-01-2015 at 03:01 PM. Reason: Price drop. |
07-15-2015, 06:59 PM | #2 |
Re: WTS OEM 12 bolt differential cover
Ttt
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
07-18-2015, 12:40 PM | #3 |
Bump. Offers?
07-20-2015, 06:32 PM | #4 |
Ttt
07-31-2015, 06:54 PM | #5 |
bump
08-01-2015, 12:47 AM | #6 |
If the edge is just bent, not cut, or the very edge damaged, then a small crescent wrench should do the trick. At least it did last night.
The bend is from a floor jack.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-01-2015, 03:02 PM | #7 |
That's what it appears to be.
Tags |
1967-1972 blazer, hat, original, plate, rear end |
