Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 08-09-2015, 09:22 PM   #1
pwdcougar
pwdcougar's Avatar
Bug spray on late model headlights
Anyone tried this besides me? Spent some time cleaning up my 97 Silverado today. The mosquitoes were pretty bad here in NJ and hosed myself down with some OFF just after I was looking at my hazy original headlights.
I'll be darned but it worked and the headlights look much better. The rag I used had a lot of yellow residue on it. Tried it on the tail lights and again they look better and the rag had the same yellow residue.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 08-10-2015, 08:45 PM   #2
pwdcougar
pwdcougar's Avatar
Re: Bug spray on late model headlights
Guess I'm the only one crazy enough to try it!
Old 08-10-2015, 10:37 PM   #3
68c10airstream
68c10airstream's Avatar
I use a clay bar on just about everything metal, plastic, or glass. A friend just told me about a meguir's product called "356". Bugs just washed off he said.
68c10airstream is offline   Reply With Quote
Old 09-08-2015, 10:04 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
2005 Malibu,2003 Grand Am
I used 2000 grit wet/dry paper(keep it soaking wet)
residue came running off with sand paper,brasso used to finish
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-08-2015, 07:09 PM   #5
TKCR
TKCR's Avatar
I use it too. I've tried the grit sanding and polishing kits in the past, this is far less work and does a fantastic job. I wish i had taken a before pic, but it was all hazed over. Looked my headlights had glaucoma, lol. And the bug spray is cheap.
Old 11-29-2015, 06:23 PM   #6
chev3600
chev3600's Avatar
I was thinking of this thread when a customer came in last week. He had a bottle of deep woods OFF in the trunk that leaked and ate through the plastic tray it was sitting in. Stuff is pretty strong if you give it time to work.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 01-16-2016, 11:05 AM   #7
JimmyK
My headlights are getting pretty bad too. They are all hazed over and yellowed which makes it really hard to see at night. I've heard of the bug spray trick, but I wasn't sure it would actually work. Does it matter if the bug spray doesn't have DEET in it?
JimmyK is offline   Reply With Quote
Old 01-16-2016, 12:04 PM   #8
TKCR
TKCR's Avatar
It does have to have Deet in it. But only use on glass headlights. Found out later that the Deet can eat the plastic if it is left on too long.
WD/40 also works good.
Toothpaste also works good too.
YouTube has a lot of videos that have shown before & after on all these products.
Old 03-06-2016, 12:52 AM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Bug spray on late model headlights
Jax Wax makes a bug cleaner that is awesome. Bug Zapper!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
