Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-10-2015, 04:42 PM   #1
SnowNeck
SnowNeck's Avatar
Steering column swap
Good afternoon. I had a tilt column with cruise control and I got a NON tilt column now waiting to go in. I noticed on the wiper switch that it doesn't have cruise control. I have a brand new wiper switch in abox that has cruise, how hard would it be to make this column have cruise? being the truck is already set up for it.
1985 High Sierra step side 4x4
SnowNeck is offline   Reply With Quote
Old 08-11-2015, 11:54 AM   #2
_Ogre
_Ogre's Avatar
Re: Steering column swap
it should be a matter of swapping the arm out for the new one and tuck the wires into the column
most gm multi-function switches are the same for that era and look like this pic
to remove the arm; push the arm in hard towards the column, twist it and then pull it out of the blinker switch
my truk has an 1986 astro column that i had to swap out the switch to match my aftermarket cruise control
shop air compressor timer
Old 08-11-2015, 12:03 PM   #3
SnowNeck
SnowNeck's Avatar
Oh alright, yeah I was able to get my hands on the correct switch, and remove the old. Now I just have to fish the wire through the column and plug it into the old connector, once I go to actually do the swap that is. Thank you for he reply
cruise, nontilt, steering, switch, tilt
