Old 08-23-2015, 01:05 AM   #1
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
What did you do to your Suburban Today?
See it in other sections and not here (Even did a search) well big girls need love too! So What did you do?
I cleaned out the interior of mine and found the missing "G" from my tailgate emblem.
It was a nice small surprise
68SWB4x4 is offline   Reply With Quote
Old 08-23-2015, 07:38 AM   #2
engairuph
Re: What did you do to your Suburban Today?
New carpet mat for the rear and oil change
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 08-23-2015, 12:10 PM   #3
Bigdav160
Bigdav160's Avatar
I washed mine. It takes a ladder to get the roof
Fixed my leaky power steering hose. Custom work never ends.
Spent some time tuning. I still have a stumble like a weak accelerator pump shot. Software tuning is new to me.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-23-2015, 01:01 PM   #4
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
HA I gave it a quick bath as well. The step ladder comes in handy
Old 08-23-2015, 01:48 PM   #5
Newtz67
Newtz67's Avatar
Took it in for an alignment. Check out the weight bench setup they have in their shop.
Newtz67 is offline   Reply With Quote
Old 08-26-2015, 12:23 PM   #6
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Rubber mat cleaned
before
after
Cleaning up the buddy bucket seat frame now to throw it in there maybe with some saddle covers for now?
Old 08-27-2015, 01:47 AM   #7
sierragrande71
sierragrande71's Avatar
Started to buff out the paint on my old girl.
sierragrande71 is offline   Reply With Quote
Old 08-27-2015, 01:52 AM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
I'd be interested in what products/process
Old 08-27-2015, 02:01 AM   #9
sierragrande71
Really all I used was 3m heavy duty rubbing compound applied by hand onto the body and wiped it down with terry cloth, probably not the easiest or most conventional way. But it works for me that's how I did my k5 and my gmc.
Old 08-27-2015, 02:02 AM   #10
sierragrande71
This is what my k5 looked liked when I first got it.
Old 08-27-2015, 02:05 AM   #11
sierragrande71
And how it looks like now
Old 08-27-2015, 02:08 AM   #12
sierragrande71
And here's the gmc, all trucks had/have heavily oxidized paint. The gmc has had a repaint in its life however. The other trucks have there factory paint.
Old 08-27-2015, 09:45 AM   #13
Hotrob72
Hotrob72's Avatar
taking my 70 down this morning to get the pipes run out the back instead if in front of the tires
1971 chevy c10 ECE 4.5/6 dropped
1970 suburban ECE 4/6 Dropped 45K original miles so far
1948 Ford Sedan
1941 Dodge COE
1932 ford roadster
the rest are normal drivers
Hotrob72 is offline   Reply With Quote
Old 08-27-2015, 10:43 AM   #14
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Continued some work on Goldmember..
Moving to the rear, I began to disassemble the rear axle in prep for the C-Notch.. Well, Guess they don't make sockets as good as the old days, with a short breaker bar I ended up with these..
So out came the sawzall and plasma.
went from this:to this:
continued on attacking the rivets.. Man I hate rivets!!
I ended the day after getting the passenger side mocked in. I only need to finish drilling a couple mounting holes, and painting all areas that will be inaccessible.
Forgot to get pics of that..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 08-27-2015, 12:42 PM   #15
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Rivet pain is FUN I went through enough of that installing my shackle flip and B52 lift kit
Old 08-28-2015, 09:13 PM   #16
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Put the seats back in including my buddy bucket set with some uhhh temporary covers. Old contest shirts from a few of the contests I've done/won until I can save up the $$ to get some fawn covers stitched up
Old 08-28-2015, 09:21 PM   #17
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
I'm going to have to do that. Once all the mechanicals are done.
I think some good shine could be brought back from this original paint
Old 08-28-2015, 09:50 PM   #18
juddss
Been busy bringing the old girl back to life. been off the road since 1990. Today I rekeyed the rear lift gate key cylinder for $10 at our local locksmith.
In the last 2 weeks I have installed headers, glass packs, welded custom bent pipes to the outside of the frame to flowmasters that exit before rear tire, ran power to my power heated memory seats, adjusted secondaries on the carb, replaced dash bulbs, rebuilt the leaking right front wheel cylinder, got the air horn working, installed rear wheel spacers. Still lots to do.
juddss is offline   Reply With Quote
Old 08-29-2015, 12:01 AM   #19
rocknss
rocknss's Avatar
I originally put a 3.5/4 inch drop on the Burb but I don't like how low it sat in the rear so today I changed the rear coils to 2 inch lowering springs and I like how it looks now.
The pic on the top is 3.5/4 inch drop and the pic on the bottom is what the Burb looks like now with a 3.5/2 inch drop.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
Last edited by rocknss; 08-29-2015 at 12:03 AM. Reason: orintation of pics changed
rocknss is offline   Reply With Quote
Old 08-29-2015, 12:07 AM   #20
sierragrande71
Looks good!
Old 08-30-2015, 12:19 AM   #21
Jbsweezy
Jbsweezy's Avatar
Removed the inner fender wells and the radiator, ac compressor, couple other things from the front of the burb.
Jbsweezy is offline   Reply With Quote
Old 08-30-2015, 02:47 PM   #22
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Took the heater box off to clean out a nest and stop some rust from spreading near the blower motor
Old 08-31-2015, 11:37 AM   #23
Twisted78SS
Wide n'Low
I think so to, here is hopefully a peek at how much it comes back to life with a little bit of effort. May be hard to tell, but in this shot I have not done the tailgate..
Had to do the same thing on mine, nice how GM built in the perfect home away from home for critters...
Air Force Retired
Old 08-31-2015, 02:32 PM   #24
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Thanks for the photo, I think I will do it some weekend my wife is out of town so she will be shocked that the truck now looks "nice"
Old 09-01-2015, 03:32 PM   #25
98L150
///Relaxed Atmosphere
98L150's Avatar
worked on my subs rear suspension
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
