Old 08-30-2015, 08:21 AM   #1
deadshort52
Where do I start A/C repair
I just bought a 71 c-20 camper special with a 402 motor. I am starting to work my way through it to make it road worthy and I want to repair the air conditioning. When I bought it the belt was taken off the compressor. I am looking for some insight on where to start. There is a little pressure still in the system so I don't expect any big leaks but I am still wondering where to go from here.
Thanks in advance for your responses.
deadshort52 is offline   Reply With Quote
Old 08-30-2015, 08:27 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Where do I start A/C repair
First, see if the compressor will turn by hand. The belt was taken off for a reason, it could be locked up.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-30-2015, 08:36 AM   #3
deadshort52
I should have stated that in the first post... The compressor does turn but it turns pretty hard, I had to turn it with a big channel lock. I know I will need a compressor but will I need a drier, accumulator and replace all of the hoses just to try it out? Do I need to get to the evaporator to clean it out? What compressor do you recommend?
Does anyone else get a kick out of a seller when you are buying something that needs a little fixing? Of course everything I asked him about that wasn't working just needed a $5.00 part and it was really easy to install...he just didn't have the time! Fortunately I know better I just always get a chuckle out that situation though.
Old 08-30-2015, 08:43 AM   #4
Katrina/10
Katrina/10's Avatar
Nothing is ever that easy, especially with air conditioning systems, there are so many things that can go wrong. The questions are, how much money do you want to spend, and how many times do you want to work on it?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 08-30-2015, 08:45 AM   #5
deadshort52
I want to fix it once and I am not overly concerned about the cost, within reason anyway.
Old 08-30-2015, 08:55 AM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
It sounds like you got somewhat lucky with your truck. I have looked at buying many, many trucks the last bunch of years and I find 90% of the time when you look at a mid-range priced truck with A/C firstly the A/C isn't working and in 90% of those trucks the compressor and accompanying brackets etc. have been removed and are not with the truck and it just behooves me why people remove everything when the A/c stops blowing cold or compressor seizes.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 08-30-2015, 09:02 AM   #7
Katrina/10
Katrina/10's Avatar
As a minimum, replace the compressor and drier. The only way to evaluate the rest of the system is to charge it up and check the pressures.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 08-30-2015, 09:05 AM   #8
jessewebb
jessewebb's Avatar
I'm working on the same thing. Without using a AC cab. So far so good. But yet so far away
jessewebb is offline   Reply With Quote
Old 08-30-2015, 09:15 AM   #9
deadshort52
I did get somewhat lucky with this truck. I am happy that at least all of the a/c components are here. Its like taking a step back in time working on this truck. Nothing has been taken apart on it as far as I can tell. Its all still here and all original.
Did the factory a/c set up work okay on these trucks or would I be better off looking into an aftermarket system?
Old 08-30-2015, 09:23 AM   #10
Katrina/10
Katrina/10's Avatar
I like factory air, but opinions are all over the place on that.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 08-30-2015, 09:37 AM   #11
Davidf
Replace compressor, go with S6, Everco, or Pro6ten (all direct A6 replacements). Replace receiver/drier. Open up system and reverse flush evaporator and condenser. If orig compressor failed, it will have sent metal debris down stream...got to get it all out. Bench test POA, search will show you how. Keep it R12, otherwise replace condenser with larger unit and readjust POA TO 26psi.
Davidf is offline   Reply With Quote
Old 08-30-2015, 01:27 PM   #12
F.A.A.benny
Recommendations from guys if going with 134a are usually to get an aluminum a6 replacement compressor(pro6ten) a parallel flow condenser and to NOT get a poa delete kit(cycling switch). The drier should be changed regardless and hoses/lines are pretty cheap from palces like LMC. If your poa valve is stuck, lmk, Ive rebuilt quite a few of them.
F.A.A.benny is offline   Reply With Quote
Old 08-30-2015, 01:48 PM   #13
deadshort52
Do you have a recommended vendor that I should buy these parts from? What condenser is recommended? Do I search for one from a different make and model?
Old 08-30-2015, 03:09 PM   #14
RedRoad
RedRoad's Avatar
benny, is that the PF condenser and drier you use on your conversions? do the factory hard lines work or do they need to be modified?
Looks great by the way!
RedRoad is offline   Reply With Quote
Old 08-30-2015, 09:05 PM   #15
hdff
hdff's Avatar
Sub'ed
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 08-30-2015, 09:10 PM   #16
jjzepplin
jjzepplin's Avatar
In!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-30-2015, 09:36 PM   #17
1972RedNeck
1972RedNeck's Avatar
I always replace the expansion valve and accumulator (or what ever you want to call it) when I open a system. If you want the stock look, good A6 rebuilds can be found easily. Unless you are going to run R12 or R12 replacements (Freeze 12, RedTech 12, or homemade refrigerant) you will want to upgrade to a more efficient condenser. Changing hoses is more of a personal preference but definitely flush them what ever you do (new or old).
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-30-2015, 09:43 PM   #18
davischevy
davischevy's Avatar
Do what makes you feel good, but,
I finished The red and white truck in my avatar in 1990 and it has been running 134 for several years now and works great with all factory components in place. This truck has been driven to Goodguys Des Moines, Cruisin the Coast, Bowling Green and Pigeon Forge on several occasions. My wife was in there, and if she is ridin' in it, the air better work.
The system was flushed, then we installed a new compressor, hoses and dryer and that's it. Flushing is crucial when switching to 134. The new compressor and dryer was just my preference of starting with new parts.
One of the most common problems with these trucks is no vacuum to the heater valve. With the engine running Make sure you have 15+ pounds of vacuum coming out of your vacuum canister mounted on the side of the "suitcase" and at the heater valve and valve on the cowl. If the heater valve doesn't work, the heater will overwhelm any cold air you have. You can get a vacuum pump/guage at any parts store.
Take note; If your defroster doesn't seem to work, that will be the diverter box in the cab. It's the greenish colored plastic box right by the hump in the floor.
We have four of these trucks, three chevelles and a 71 Corvette, all with factory components and 134 refrigerant.
I work under the premise "If it's on there I want it to work and work well". but I also like to keep it simple. I drive my cars and if I break down, I want to be able to call O'Reilly and tell them what to bring to fix it.
Larry
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 08-30-2015, 09:49 PM   #19
Steeveedee
Who Changed This?
Steeveedee's Avatar
If you are only air-conditioning the cab of your truck, that A-6 compressor is complete overkill. That compressor was designed by GM to cool even a big black Buick station wagon in the desert where the nearest shade was 100 miles away.
If the belt was removed, it could just be that the clutch shoe has bad springs. You can replace that shoe easily. I'd recommend taking it to several shops who can lay eyeballs on it and give you an estimate. You will be amazed at the differences in cost. Use your judgment on how crazy the answers are. Then get back to us...
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 08-30-2015, 09:57 PM   #20
Steeveedee
Who Changed This?
Steeveedee's Avatar
Accumulator, or receiver/dryer. Homemade refrigerant could include propane. That is what is generally used in Australia, though it isn't really "homemade" there. I'm not in/from Australia, I just have a wide data base. Propane may require a different lubricant. Interestingly enough, there doesn't seem to be a large reporting database about traffic accidents in Australia where vehicles caught fire in an accident where the AC system was breached. But that is one reason that non-flammable refrigerants are used in the US.
~Steven
Simi Valley, CA
Old 08-30-2015, 11:00 PM   #21
1972RedNeck
If you think about how little refrigerant is in an A/C system, it wouldn't make a very big bang if it were full of propane.
1966 F250 4X4 416
1972 K20 350 4 OTF
Old 08-30-2015, 11:30 PM   #22
Mapearso
subscribed!
Mapearso is offline   Reply With Quote
Old 08-31-2015, 01:39 AM   #23
F.A.A.benny
I cant take credit for that setup. That picture came from one of the fb goups. But I can tell you that it is a parallel flow condenser, unlike the ones that Old Air Products and Classic Auto Air sell
I cant seem to verify it. I was told it came from Silla but when I looked it up on their website, the image looks like the ones that old air and CAA sell. Called them but the csr on the line didn't really know much or couldn't verify it either. I don't want to spend the $200 its gonna cost to get it to me just to verify. If not, then I can already envision the hassle with returns and probably me having to pay the shipping back/20% restocking fee. Also, I would not be using that style of drier in the pic. That is a steel drier. You can pick those up at any auto parts store. I like the factory aluminum reproductions. They cost a little more but they look better. Oh and don't buy them from Old Air Products unless you happen to like paying 2 times what you can find them for on other sites. Now you can purchase a rebuilt one from old air( gotta have your core, or its $125 core charge) or you can just have yours rebuilt by them. CAA offers this same service.
Old 08-31-2015, 02:18 AM   #24
RedRoad
RedRoad's Avatar
Cant wait to see the pics of the set up you are currently restoring. If you put a kit together with the PF condenser, dryer, compressor with options on recalibrated POA, evaporator, lines etc you would do well. Most folks with factory air would rather rehab their systems instead of pulling it all out and going aftermarket.
Old 09-01-2015, 02:40 AM   #25
F.A.A.benny
Also forgot to say that the factory hard lines would work without needing to modify them.
