Old 09-09-2015, 07:55 AM   #1
joeydirt
Toyota Timing Belt
Am I allowed to talk about yotas here? heh
I think Im good to go here but wanted to get some thoughts before I actually fire it up since its an interference motor. So I changed the timing belt on my 4.7 tundra using the 50 degrees ATDC mark at the crank and the T marks on the cams and after a few manual rotations they got out of sync. I thought I did everything right but apparently not either the belt slipped or I need glasses. So I tried again but this time using the TDC mark on the crank and cam, and everything stays in sync. I have the plugs out for ease of rotation and there does not seem to be any resistance or noises. Allthough Im not sure there would be if there was a timing issue and the valves and pistons were crashing. So thoughts? Some of my readings indicate its is a bad idea to rotate the cams without the belt hooked up but Im assuming this is to avoid spinning the cam when a piston in that bank is at TDC so you dont bend a valve.
joeydirt is offline   Reply With Quote
Old 09-10-2015, 12:17 PM   #2
NONHOG
NONHOG's Avatar
Re: Toyota Timing Belt
What year? I can look it up on TIS for you.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 09-10-2015, 02:02 PM   #3
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Welcome to the site.
I used to own one of those 4.7's in a four runner a while back. Great engines. I am getting ready to do a timing belt swap on my 3.3 in my Highlander and have found a wealth of "how to" information on Youtube. Look up your engine in their search feature and I am positive you will get all the information you need in video form.
Let us know how it turns out.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 09-10-2015, 10:10 PM   #4
joeydirt
2002
YouTube has a couple of videos but I think I have strayed from there work flow at this point
Old 09-11-2015, 03:04 PM   #5
NONHOG
NONHOG's Avatar
pm me a fax #
I have 6 pages from the factory repair manual.
Hope it helps!
Old 09-14-2015, 11:17 PM   #6
68c10airstream
68c10airstream's Avatar
My neighbor has a 4.7 in a toyota and i looked up the recommended service intervals and it mentioned valve clearance as a needed item. I believe it's a 2004. Further searching on alldata pro found that the style of valve clearance adjustment is a select fit disc. You measure the clearance, record it, and then look on a chart and order the new correct thickness disc id adjustment is needed. If memory is correct my recommendation by 100,000 miles was a t-belt, tensioner, waterpump (might just as well) and the valve clearance adjustment as per the service sheet. Good luck.
68c10airstream is offline   Reply With Quote
Old 09-15-2015, 08:06 AM   #7
joeydirt
jobs complete, I was just being paranoid I guess. Thanks for all the help
