Old 09-10-2015, 12:40 AM   #1
Andy4639
Old member
Andy4639's Avatar
Question New Radiator
Has anybody used one of these?
They say it's a direct drop in for our trucks and it has the Tranny coolier to.
http://www.ebay.com/itm/281405991455...%3AMEBIDX%3AIT
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-10-2015, 12:51 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: New Radiator
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-10-2015, 01:05 AM   #3
toolboxchev
Re: New Radiator
By the looks of it, I would say its used?
Brass and copper for me.
toolboxchev is offline   Reply With Quote
Old 09-10-2015, 01:05 AM   #4
elkniks
elkniks's Avatar
Re: New Radiator
That looks quite square at the welds to drop in without some serious modification to the factory mounts. I just installed an Engineered Cooling Products (ebay) unit and had to remove most of the rubber from the stock mounts and clearance the brackets with a grinder to make it fit.
elkniks is offline   Reply With Quote
Old 09-10-2015, 01:19 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: New Radiator
Thanks for the info but my 71 isn't no where near stock. I have a cover to hold it in up top and the bottom I can mod to work.
Just want to know if it's a good product. Going to be using dual fans also.
Old 09-10-2015, 10:28 AM   #6
Z10
Z10's Avatar
Re: New Radiator
Andy,
I'm using this radiator in my 72. Fit's great and works great.
http://www.speedcooling.com/1967-197...r/prod_38.html
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 09-10-2015, 10:44 AM   #7
cdowns
cdowns's Avatar
Re: New Radiator
that bottom hose location doesn't havev the factory angle built in . i'd think that radiator might have a clearance problem with the front crossmember
for the price i'd much rather stick to a stock over the counter ones available at my local parts house instead of a mailorder one
Old 09-10-2015, 03:51 PM   #8
Andy4639
Old member
Andy4639's Avatar
Question Re: New Radiator
toolboxchev
It says it's brand new!
Originally Posted by Z10 View Post
Andy,
That looks nice also. Thanks for the link.
cdowns
Thanks but that want effect mine since I have the LS motor installed. I don't think. I have a O-Reilly one in it now and it's leaking. The tanks are coming a part again. I've had it fixed once already. I was just thinking the aluminum radiator would be a better one, who knows for sure but it being all welded seems to be a good start. The bottom outlet does curve up so I think it OK.
Old 09-10-2015, 04:18 PM   #9
toolboxchev
Re: New Radiator
Where did you get those rad radiator hoses?
Old 09-11-2015, 12:40 AM   #10
T.B.A.
Re: New Radiator
I'm pretty sure that's exactly the same as one that I bought off ebay.
Dropped straight in, has the correct angle on the bottom outlet and hasn't caused any problems, so far. I bought it just to get the C10 on the road until I make a "good quality" aluminium one myself, but so far, it can stay!
T.B.A. is offline   Reply With Quote
Old 09-11-2015, 09:58 AM   #11
BossHogg69
motor exploder
BossHogg69's Avatar
Re: New Radiator
Andy,
I'm using the same one, bolts right in with factory mounts and all, everything hooked up correctly. I'm running mine with Derale dual electric fans and it keeps my motor nice and cool, even with the air on.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 09-11-2015, 10:43 AM   #12
Custom 68
Custom 68's Avatar
Re: New Radiator
Adam I was at a swap meet and there was a booth selling what appears to be the same radiator. I got one and so far I really like it. It has the 2 large "cores" that the coolant really pours thru. It did fit well and seems to be better than my old original.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-11-2015, 01:01 PM   #13
Andy4639
Old member
Andy4639's Avatar
Talking Re: New Radiator
OK guys that does it. I'm going to order it today for my birthday!
Old 09-11-2015, 07:48 PM   #14
elkniks
elkniks's Avatar
Re: New Radiator
That link above is the same radiator I am using. The hoses I found on Ebay, they were the only preformed silicone hoses that I could find for our application. They were cheap too, so I figured I would give them a shot. I did not expect much but they fit perfect and so far (a couple of weeks) are holding up. If you buy them do not use the clamps that come with them, make sure to use hose clamps designed for soft hose(McMaster).
Old 09-12-2015, 06:54 PM   #15
Andy4639
Old member
Andy4639's Avatar
I ordered the radiator it should be here next week sometime. I already have dual fans and I have a aluminum shroud already but haven't cut the holes yet for the fans. I'm going to wait and get everything together before I cut anything.
Stay tuned I'll do a write up when I get everything.
Old 09-13-2015, 04:40 AM   #16
BigMike
BigMike's Avatar
Re: New Radiator
I would recommend a zinc anode to prevent the aluminum from corroding. You can get one that replaces the drain petcock and it will keep your radiator from corroding. I wouldn't buy the more expensive flex-a-lite ones, just get a generic one. Here is a flex-a-lite eBay listing so you can read why it is important. flex-a-lite zinc annode
Here is one a lot cheaper eBay cheap zinc annode
BigMike is offline   Reply With Quote
Old 09-13-2015, 11:23 AM   #17
Andy4639
Old member
Andy4639's Avatar
Thanks.
Old 09-14-2015, 11:58 PM   #18
Lancialonnie
Re: New Radiator
I look forward to hearing what you think of this radiator once it is delivered. I'll be wanting to replace mine eventually but not for a while as my truck is still at the paint shop. Turns out the floor pans were worse than we thought so I just ordered new pans, then the metal cutting and welding can begin!
Lancialonnie is offline   Reply With Quote
Old 09-15-2015, 02:58 PM   #19
Andy4639
Old member
Andy4639's Avatar
Several of our local truck club guy's
https://www.facebook.com/groups/UpstateGMtrucks/
have ordered the Champion one which looks just like the one I ordered and they love it. I hope to get it by this weekend so I can get started on the install. I'll take pictures and write up as I go.
Old 09-18-2015, 07:00 PM   #20
Andy4639
Old member
Andy4639's Avatar
My new radiator showed up today. 3 days earlier than tracking showed!
I'm going to flush it out good tomorrow and start draining the one in the truck.
I'll swap all the fittings and polish it up before installing.
It showed up right before I left for work but it looked great but will look it over good tomorrow. So far I'm impressed with the look of it!
Old 09-18-2015, 07:40 PM   #21
Lancialonnie
Re: New Radiator
Looks good! I hope it fits well and works for you. If you follow the link now it says the price is $957, OUCH!
I guess I won't be buying one at that price!
Old 09-18-2015, 08:39 PM   #22
Andy4639
Old member
Andy4639's Avatar
If you drop down a few post I posted another one for him with fans and it's only $169.00.
Old 09-18-2015, 08:43 PM   #23
EARNHARDT#3
EARNHARDT#3's Avatar
Re: New Radiator
I have the same one for a year now. I dint have the money for a good radiator and I couldn't bring myself to put in a plastic radiator so I got one of these. Hasn't leaked yet and of course it cools my 250!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-18-2015, 09:57 PM   #24
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: New Radiator
Good deal! I'm going to have the daul fans with the shroud I had made about a year ago for the old one but when I noticed it leaking I kept putting it off. I will install the shroud and fans both now and hope it last for a long time.
This thing should be even better at cooling than the old one. At least I hope so any way.
This is the one in the truck now. Not the greates picture but you can see the fans and old radiator.
I'm also going to swap the relay's out for some of these I think! You can get them in about any amp size you want. I'm thinking it should let the fans run cooler and they should last longer and take the amp draw off the wiring also.
Old 09-19-2015, 12:44 AM   #25
Z10
Z10's Avatar
Re: New Radiator
Andy,
I just replaced the cap that came on mine, because it wasn't holding pressure. Just keep an eye on yours. I replaced it and all is well.
I think you'll really like it. I just completed a 600+ mile trip in the Texas sun last weekend, and the temp stayed rock solid on 185.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
