Old 09-11-2015, 09:47 AM   #1
wingnut6999
wingnut6999's Avatar
idler arm
Any advice, tricks, tips on replacing the idler arm on my 72. Gonna do the tie rods while I'm there.
wingnut6999 is offline   Reply With Quote
Old 09-11-2015, 10:35 AM   #2
ERASER5
ERASER5's Avatar
Re: idler arm
Pull the tie rods first or the drag link will be flopping around. Then do the idler. The idler and pitman arm hold the drag link in place. Makes things go a bit easier.
Remove the ball joint from the drag link first. If a hammer doesn't knock the joint apart, get a pickle fork. My pickle fork has a screw on handle for hammering and an air hammer adaptor for the air hammer. Guess which one I use.
Then the 2 bolts from the frame. Pretty simple.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
