09-11-2015, 09:16 PM | #1 |
ECE front brake hose replacement?
I bought one of the ECE front disc brake conversions for my 68 C10 and I just found that one of my front rubber hoses got pinched and needs to be replaced. I was hoping to find a replacement at a local auto parts but I've had no luck so far.
Does anyone know of a good replacement for this? I was really hoping to get it fixed this weekend. Thanks, Rich |
09-11-2015, 09:55 PM | #2 |
Re: ECE front brake hose replacement?
why wouldnt one off a mid 80's truck work
09-11-2015, 10:00 PM | #3 |
Moderator
They are conversion hoses, ends are different.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
09-11-2015, 10:02 PM | #4 |
someone mentioned a 78 Camaro hose in a post but I could not confirm the size on one. I would like it to be longer than this one.
09-11-2015, 10:26 PM | #5 |
Napa 36616?
09-11-2015, 11:22 PM | #6 |
09-11-2015, 11:59 PM | #7 |
Look it up on NAPA and I think you can get the specs so you know before you go. My NAPA had to order it... which took 4 hours to arrive!
NAPA is sometimes (not always!) a little more expensive. But most of the stuff is good and the catalogs and parts guys a little sharper. Been very helpful with the 70. |
09-12-2015, 12:04 AM | #8 | |
09-12-2015, 12:28 AM | #9 |
If you have a local shop, have one made. I toyed a round a bit with some repro., sent em all back. Will have everything made instead.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-12-2015, 09:41 PM | #10 |
The Napa 36616 worked perfectly, it is a little shorter than the hose from ECE but everything else is the same. The shorter hose actually works better with the lowered truck now I don't have to worry about it getting pinched. Thank you picklito for the part number.
09-13-2015, 02:25 AM | #11 |
Oh man thats great! That's the hose NAPA gave me to try for my swap, but I'm still a week or two away.
09-14-2015, 12:43 AM | #12 |
Moderator
Great info! I cross referenced the Napa part number with autozone and oreillys. They all carry them on the shelf, $9.95 each. I picked up a pair of hoses....AND new calipers, pads, and banjo bolts for the same amount of money it would have cost me for the hoses alone from ece. The hoses have been the only part keeping me from doing a budget disk brake conversion using off the shelf parts locally available.
09-14-2015, 11:13 PM | #13 | |
Thanks, Rich |
