Old 09-12-2015, 12:54 PM   #1
jcblue
jcblue's Avatar
In need of some experienced alignment help
I have taken my truck to the alignment shop and have been told I need to do something different.. I have a 72 static drop 5/7 using 3 inch springs and western chassis 2 inch spindles. I will attach a pic at the bottom but as you will see there is a lot of negative camber.. Alignment guys says he doesn't think he can put enough shims in there to bring it out and if he can he said he wouldn't feel right about running it like that.. When the truck was apart I took it to the frame shop to make sure all the specks were right.. I have ordered a set of one inch narrow lower control arms from Porterbuilt but am wondering if that's necessary bc I see so many trucks running the stock arms with what seems to be about the same stance.. Any info or opinions would be awesome
jcblue is offline   Reply With Quote
Old 09-12-2015, 01:01 PM   #2
jcblue
jcblue's Avatar
Re: In need of some experienced alignment help
Let me know if you want other pics
Old 09-12-2015, 09:17 PM   #3
mixermike
mixermike's Avatar
I would try a different shop and see what they say.
mixermike is offline   Reply With Quote
Old 09-13-2015, 01:58 AM   #4
CastIron
CastIron's Avatar
How much camber is it? Is your alignment guy aligning it to the original specs? When I did mine (not lowered) I just made up my own specs. I set it at -.25 camber, +1.5 caster, and it toed in just a little, and it drives pretty decent. I'm sure your camber is more negative than that, but it may not wear the tires abnormally. I'd get a second opinion.
CastIron is offline   Reply With Quote
Old 09-13-2015, 03:33 AM   #5
toolboxchev
I believe Moog makes a Upper Control arm shaft kit to address this. Check them out for parts, those things are not that expensive.
Ask me how I know this? They have an offset to address the lowering issue therefore you would not need all the shims.
toolboxchev is offline   Reply With Quote
Old 09-13-2015, 03:47 AM   #6
BigMike
BigMike's Avatar
Mine is 5.5" up front and 6' in the rear and I had mine done no problem. I'm using the older CPP 2.5 spindles with 3" springs.
I would definitely try another alignment shop before I start spending $$$ that may not be needed.
BigMike is offline   Reply With Quote
Old 09-13-2015, 06:39 AM   #7
jcblue
jcblue's Avatar
Thanks for the replies
Old 09-13-2015, 07:40 AM   #8
72MARIO
72MARIO's Avatar
My 72 short box had 2" drop coils and 2.5 spindles and the most camber we could get out of it was -.25 on one side. Any lower and we would have been negative on both side i bet over 1 degree. 3" dro coild have been known for difficulties in alignment.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-13-2015, 09:07 AM   #9
Kennuck
Kennuck's Avatar
Moog part number is K6256 if you decide to go that way.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 09-13-2015, 09:16 AM   #10
chiefcfd
chiefcfd's Avatar
jcblue, what shop are you using. I've heard good things about Randy's Automotive in Hoptown. That's where I'm taking mine as soon as I can get there.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 09-13-2015, 09:52 PM   #11
jcblue
jcblue's Avatar
Thank you for the replies
And part number.. I'll check that out
