09-11-2003, 07:17 AM | #1 |
What did this
This uneven wear is only on the
drivers side. Any advice?
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
09-11-2003, 07:31 AM | #2 |
You need an alignment.
The toe adjustment is out of whack. If the front suspension had adjustable camber, it could be that. |
09-11-2003, 08:51 AM | #3 |
I second that
09-11-2003, 10:31 AM | #4 |
Do you rotate your tires? With everything snug and tight on these, there is an ever so slight amount of positive camber with the steering straight(the top of the tire leans out). If you've never rotated the tires, this might be the cause. Of course, both fronts should have the same type of wear if this was the cause.
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast" '04 Silverado (new daily driver) '00 Intrepid (wife's ride) It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER.... |
09-11-2003, 11:40 AM | #5 |
SKINNY TIRES RULE!
Could be a bad ball joint too. But the wear from that would most likely be on the inside.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-11-2003, 01:24 PM | #6 |
The other side has even wear. Sometimes I hear a "pop"
when turning real hard to the right and standing still. Like when I am getting out of a parallel parking space.I think if I rotate tires it would just wear out all 4 quicker. If it is alinement are the fronts seprate? I ask this because the passange side wears perfect. Thanks everyone,
09-11-2003, 01:56 PM | #7 |
I don't know. It sounds terminal. If you want I can run up there from the Bayou state and take that "wreck" off your hands before it starts nickel and diming you to death. Seriously, If you are getting a "pop" on turns, it's probably a ball joint. I've had all 4 of mine replaced in the last 40,000 miles, but I run a larger tire than you do too. Might not hurt to check for bearing slack either.
09-11-2003, 06:41 PM | #8 |
Thanks 3wbdriver (lol)
How much money are we talking about? I mean to fix ball joints.
09-12-2003, 11:16 AM | #9 |
I think I paid $100 give or take, to have the last 2 replaced. They did it in conjunction with a front end alignment.
09-12-2003, 11:33 AM | #10 |
SKINNY TIRES RULE!
I was quoted around $700 to do all four from several places. With a few new tools, I pulled the old knuckel off and took it to Midas to have the new ball joints pressed in. I think they charged me $20 to press it in. Harborfreighttools had a press for $20 right after I finished mine. I also replaced the axel u-joint on one side and did a break job since it was all ready apart. My ball joint was so shot, I had to use a grinder to get the castle nut off the top because the whole ball joint was just spinning freely.
09-13-2003, 02:19 AM | #11 |
go cyclones
As much as I hate it I will have to do a good once over of my suspension soon.
