09-15-2015, 07:46 AM | #1 |
Help me identify the part number
Hi all,
I am having a problem with the automatic column shift linkage on my 1978-1979 hybrid pickup. The bracket that mounts to the frame has rusted away. I am having trouble finding just the bracket. It is the same as in this ebay ad: http://www.ebay.com/itm/73-77-78-79-...f0d828&vxp=mtr Any ideas? Thanks, Evan |
09-15-2015, 07:08 PM | #2 |
Re: Help me identify the part number
I believe all c10 k10 and k5 with an auto trans use the same bracket so you should be able to go to find it do you want used or are you looking for a new one
<Brandon> 1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works. 1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15 81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in 1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096 1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195 |
09-15-2015, 09:37 PM | #3 |
Used would be fine. This truck is near the end of it's life - I am just trying to squeeze the last bits out of it.
09-15-2015, 09:56 PM | #4 |
I would go to the wrecking yard they are bolted on with two 5/16" bolts 1/2" wrench size if I remember right shouldn't be to expensive probably $10-15
09-16-2015, 07:18 AM | #5 |
Any new sources that anyone knows of?
09-16-2015, 07:38 AM | #6 |
I show:
15614398 and 6271386 both of which have been discontinued. (1985 parts book shown) K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-16-2015 at 07:56 AM. |
09-16-2015, 09:42 PM | #7 |
Tags |
automatic transmission, parts needed, shift linkage |
