Old 09-19-2015, 07:50 PM   #1
72 tigger
72 tigger's Avatar
14ga lower door panels
Replaced my rusted out outer door sheet metal with 14ga metal. I cut out all the rot & coated everything with POR-15 then welded on the sheet stock. I didn't repair the inner metal (more room for the water to get away. Hope it holds up against the salt! This is my work truck & doesn't look perfect- thanks for looking
72 tigger is offline   Reply With Quote
Old 09-20-2015, 07:24 AM   #2
Redline novdog
Redline novdog's Avatar
Re: 14ga lower door panels
Nice job! Did you coat the inside with por-15 after welding?
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 09-20-2015, 04:00 PM   #3
72 tigger
72 tigger's Avatar
Yes, I did coat everything before paint. I hope the lack of a seam at the bottom helps slow the rust
