09-20-2015, 05:43 PM | #1 |
timing question
I have a GM 290hp/350 with HEI. in the installation and break in procedures GM says to disconnect and run the engine without the vacuum advance. I've never heard of this.
09-20-2015, 06:10 PM | #2 |
Re: timing question
To set your basic timing ,yes.
09-20-2015, 06:36 PM | #3 |
Re: timing question
Gm's paperwork indicates that "this engine is designed to run on mechanical advance. The initial 10 degrees will produce 32 degrees total advance at WOT
09-20-2015, 08:55 PM | #4 |
Re: timing question
It's simply the bean counters in the warranty department.
They don't want you to put too much timing into the motor and hurt it and cause a warranty problem. |
