Closed Thread
Old 09-22-2015, 09:39 PM   #1
original condor
K-10 front spring situ & info
Howdy All. My rig is a 70 longbed 350 manual trans., 308 gears & power steering / brakes. My front leaf springs are 44" long. This matches the length of the new ones sold by LMC, so I'm betting on that being stock. Existing shackles look stock too. My issue is that the springs are so long?...flattened? etc.? This has the shackles at a radical angle towards the rear with the truck at rest & level. It is so bad that the springeye at the rear end of the spring is rubbing on the frame
& also rather than the shackles pivoting when the spring flexes, it just puts a stretching force on the shackles and all the bushings, etc connecting it to frame on it.
My question is this, on my limited budget, should I get the stock replacements mentioned above( about $340 plus tx), hoping this doesn't occur again. Or should I find, or have made, or whatevers needed, to get some springs with similar curvature, leafs, etc, that are 2" minimum, and up to 3" shorter eye to eye. This should put the schackles in a near vertical position, preventing the spring from touching the frame again, keeping the ride nicer.
By the way, I'm also doing a ORD rear shackle flip to get rid of some 4" blocks. I know they don't make a exact kit for our 67 to 72. but that you can adapt the square body one to work. If someone has actually done it, please tell me how long it would take a novice, & his buddies, with reasonable tools tp pull it off? Also any pitfalls to be ready for? Thankyou...........Steve
70 Custom K-10 LWB w/ mild build 350
Sm465 & 205 +GM truck 12 bolt rear
Dana 44 up front....3.08 ratio
33" 12.50 15 on 8" rims
46" front leafs
52" rear leafs
original condor is offline
Old 09-22-2015, 09:42 PM   #2
Mike C
Mike C's Avatar
Re: K-10 front spring situ & info
This is a duplicate post.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is offline
Closed Thread
