Old 09-23-2015, 09:23 AM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
60-62 Frame Horns
Common problem with them cracking and breaking.
I had hoped to replace them with the 63-66 style, but it's not just about the bolt spacing, the 60-62 bumper contour is different than the 63-66.
I know I could find someone who has a nicer set they could cut off an old frame, but I'd like to see if we could come up with another solution. Has anyone fabricated their own new horns?
66 C20 Service Truck:
Old 09-23-2015, 11:28 AM   #2
LostMy65
LostMy65's Avatar
Re: 60-62 Frame Horns
I actually made it this far before I realized the shape of the bumpers are different. I knew the bolt spacing was different, but I didn't realize the shape of the bumpers on 63-66 were different from the 60-62.
Old 09-23-2015, 11:33 AM   #3
oem4me
You've gone that far, why not just find a 63-66 bumper to fit the new horns? Or am I missing something?
Old 09-23-2015, 01:45 PM   #4
LostMy65
LostMy65's Avatar
They're not welded yet. Just hanging there for mock up.
Yes, I've considered getting a 63-66 Chrome Bumper.
I've got one more thing I'm going to try.
I would rather not spend $180.
Old 09-23-2015, 02:02 PM   #5
60-66
60-66's Avatar
Isn't the 63-66 frame taller here ? Might interfere with the grille surround . The notches in the surround for 63-66 are taller or deeper than 60-62.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is online now   Reply With Quote
Old 09-23-2015, 02:08 PM   #6
LostMy65
LostMy65's Avatar
yes, my grill support happens to be from a 65. my 65 is on a 62 frame.
Old 09-23-2015, 04:09 PM   #7
LostMy65
LostMy65's Avatar
I'll chalk it up to another lesson learned.
No big deal. I went ahead and repaired the 62 horns.
I'm comfortable with my welding skills.
I'll just weld them back on.
Old 09-23-2015, 10:47 PM   #8
61ChevyPanel
Active Member
61ChevyPanel's Avatar
My front frame horns are shot too so if anyone has '60-'62 horns or another solution, please reply.
61ChevyPanel is offline   Reply With Quote
Old 03-05-2016, 11:55 AM   #9
LostMy65
LostMy65's Avatar
I cut mine off. Bolted the broken pieces to the bumper. Tack welded the pieces together. Then welded the repaired horns back on.
Old 03-05-2016, 03:40 PM   #10
Tazimafied
I would weld in some gussets to keep it from happening again.
Tazimafied is offline   Reply With Quote
Old 04-05-2018, 07:02 PM   #11
LostMy65
LostMy65's Avatar
Saving ron's post for future reference:
Originally Posted by padresag View Post
here is the difference in the profile black line is 62. red is 66
ron
Old 04-22-2018, 01:02 PM   #12
Thiessen1960
I am in the same predicament. I currently have a set of frame horns from a 63-66. If I welded those on to my 60 Chevy would I just have to use the 63 to 66 bumper?
Thiessen1960 is offline   Reply With Quote
Old 10-08-2018, 11:57 PM   #13
LostMy65
LostMy65's Avatar
Yes
Old 11-08-2018, 04:59 PM   #14
LostMy65
LostMy65's Avatar
Yes, I just want to do few more alignment checks before I reinforce them.
Old 06-21-2021, 05:37 PM   #15
LostMy65
LostMy65's Avatar
It's almost like there should be a reinforcement piece that could be fabricated to bolt to the existing frame. That way even those without the ability to weld could just bolt it up.
