Old 09-23-2015, 04:02 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
What is this part called?
It's the ghost image above number 15....... Number 15 attaches to it. It's for the Inside AC to Defroster control. I have a question about this unit, and would like to sound nearly intelligent when I ask. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=167
Thank you
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-23-2015, 04:23 PM   #2
Davidf
Re: What is this part called?
Good question. It function is to divert air from floor to defrost vents. So, I would call it the "heater/defrost diverter box". Not reproduced the best I could determine.
Davidf is offline   Reply With Quote
Old 09-23-2015, 04:40 PM   #3
71CHEVYSHORTBED402
Exactly. Seems like a good label............ I've looked in a few places. They seem to reproduce everything else. I think I'll call mine a "Inside Air/Defroster Selector", beings that's consistent with how the A/C/heat controller is labeled.
Tony
Old 09-23-2015, 04:46 PM   #4
Davidf
I think the reason the box is not reproduced is that it is made from sheetmetal and not in a location that would make it susceptible to rusting. So, the box is durable and thus the replacement market/demand small. Most/all the other parts are plastic and subject to cracking/breaking/deforming and thus market/demand is high.
Old 09-23-2015, 04:47 PM   #5
71CHEVYSHORTBED402
Which leads me to my next question. Don't want to mess something up. I'll put it in another thread.
Tony
Old 09-23-2015, 04:51 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Diverter box. They come up for sale on the parts board, see NOS units on eBay, and Brothers used to sell them, not sure if they still do or not.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-23-2015, 05:22 PM   #7
cdowns
cdowns's Avatar
In my 71 &72's with ac they were made out of plastic from the factory and have been available at least 20 years or so in repops
Old 09-23-2015, 11:56 PM   #8
71CHEVYSHORTBED402
The "diverter box" for the "inside" air control is steel. If you search for diverter box, the new ones appear for the A/C. From a limited search (including Brothers), these may no longer be reproduced. Note: I don't need one, just wanted to know what called.
The diverter box for the A/C and the "S Duct" are plastic. You can locate repro.
Tony
Old 09-24-2015, 06:59 AM   #9
cdowns
cdowns's Avatar
I do believe that the item #12 is called the diverter box because of the flspper valve enclosed in it that diverts the air where you want it to go
Old 09-24-2015, 11:06 AM   #10
ERASER5
ERASER5's Avatar
I think he is talking about the grayed out un-numbered and un-named part in that diagram.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-24-2015, 11:52 AM   #11
EARNHARDT#3
EARNHARDT#3's Avatar
Nowadays this part is called a "blend door"
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-24-2015, 01:37 PM   #12
mrein3
mrein3's Avatar
the grayed out thing - which I think is what you are asking about not only is inside and durable like Davidf pointed out, but it is the same on AC and non-AC trucks so EVERY one out there has one making any part-out a potential donor.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-24-2015, 06:26 PM   #13
71CHEVYSHORTBED402
The flapper on the grayed out image (""Inside" Air/Defroster Selector Duct") has a piece of rubber (approx 3" wide x 5" long x 3/16" thick) mounted to the flapper with three staples. This piece runs on both sides of the flapper. It's likely the rubber is cracking on yours, right where it bends.
Could try locating a piece of rubber that's durable and flexible (reference runs on both sides). Could make due with two rubber pieces instead.
I likely won't take it off the hinge. Not worth chancing a scratch or break. I don't have staple gun to go through that anyway. Doesn't mean I can't replace it. It's that or call it a day already. May not live long enough to require a replacement.
Tony
Old 09-24-2015, 06:45 PM   #14
71CHEVYSHORTBED402
BTW, my attempt to sound nearly intelligent backfired. I just wasn't wearing my glasses.
Tony
Old 09-24-2015, 08:22 PM   #15
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What is this part called?
The part you are talking about is to direct air either for the floor heat are for the defrost to windshield. The one in my 71 AC truck is metal and if I'm not mistaken they are the same thing on either AC trucks are just heat.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
