Old 09-28-2015, 10:33 AM   #1
cjoenny89
cjoenny89's Avatar
Starter wiring
I happen to look down last night and see a single yellow wire hanging by my starter. It looks like it bolts to the starter solenoid. Does anyone know what this is for and where it goes? Truck still starts
68 C20 327 3OTT
cjoenny89 is offline   Reply With Quote
Old 09-28-2015, 10:35 AM   #2
Zeke's Garage
Zeke's Garage's Avatar
Re: Starter wiring
Are you running an HEI? Have you tested it for power when the key is on? What kind of terminal does it have, a ring or push-on clip?
Also a quick photo will help tremendously.
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 09-28-2015, 11:14 AM   #3
cjoenny89
cjoenny89's Avatar
Re: Starter wiring
I am not home right now but it is factory wiring truck was un-touched from 1988 until last fall and before that my dad tore it apart it was my grandfathers truck.
I am running HEI but we just put that on last fall. and we just used the same wire off the original distributor (which was yellow) for power since it had 12volts with the key on and now that you say that the truck is running bad I thought it was due to a plugged fuel filter that I just changed and was just about to clean carb. I think it has a ring on it that wire which broke but it is still on the statrer but not 100% sure.
Old 09-28-2015, 11:54 AM   #4
Gromit
Re: Starter wiring
Here's a few photos that might help.. this is on a 1970 with points ignition
(I realize you aren't asking about the power cable but I should mention the positive cable to starter connection seen in the attached 2191 and 2193 photos is not stock of course - that part is a DIY from a pc of copper plumbing pipe, heat-shrink, and a sparkplug cable boot - the cable as it came from LMC is what you see in the photo 2164 and it didn't seem to fit right)..
Hope that helps
Gromit is offline   Reply With Quote
Old 09-28-2015, 12:17 PM   #5
Lou Boffa
Lou Boffa's Avatar
Re: Starter wiring
subbed
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 09-28-2015, 03:51 PM   #6
Wrenchbender Ret
Re: Starter wiring
This wire is for a bypass to send full voltage to the coil when starting. It is not used with HEI. But, you should not run HEI off the original wire to the coil. It goes through a resister & is not heavy enough gauge for it. I like to tie into the pink wire on the ign switch with a 12 gauge wire right to the power term. on the HEI unit.
Wrenchbender Ret is offline   Reply With Quote
