09-28-2015, 06:01 PM | #1 |
Truck keeps stalling out please help
I have 68 C10 with a mid 80's SBC and a 350 automatic transmission. Everything on the engine is new expect the fuel pump and plug wires. My problem is the truck will run fine for a few miles then it begins to stall. I work the gas to keep it running. The problem is intermitting and the engine may be hot or cold. We have set the timing and vacuum. We idle it up because it wants to stall when put in drive. I went as far as having the torque converter checked.
The Quck fuel carb is brand new too. Please help. Any suggestion appreciated. |
09-28-2015, 07:34 PM | #2 |
Re: Truck keeps stalling out please help
might not just be the fuel pump. Is the pickup clear in the fuel tank? I seen fuel socks(tank pickup filters) get partially clogged and closes off fuel supply at any time or temp.Just an FYI.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
09-28-2015, 08:06 PM | #3 |
Old member
Does it do it at 1/2 a tank and below more than when full? Could be a bad sock are it could be a vacuum being pulled on the tank.
09-28-2015, 08:56 PM | #4 |
New parts don't always mean working parts. What condition is your fuel line and filter in?
09-28-2015, 11:03 PM | #5 | |
The Older Generation
Next time it does it try removing the fuel cap and see if it sucks air in when you loosen it up. Could be pulling a vacuum like Andy said. Do you have a fuel filter on it? If so where is it? LockDoc
09-28-2015, 11:45 PM | #6 |
YOu might want to try adjusting the arm that drives the accelerator pump. You would be surprised by how much grief those can give if they are "feeding fuel" by the arm pushing down even slightly. Holley says there is supposed to be a "slight drag" on a 0015 feeler gauge when inserted between the arm bottom and the pump arm. Adjust it till it does not touch and then adjust back towards the arm.
JMO
"Life is too short to drive a boring vehicle". Later, Wayne |
09-30-2015, 02:22 AM | #7 |
New engine? did the intake get retorqed? I had a stalling problem and was frustrated as no amount of tuning seemed to help, it would be fine then 2 minutes later the stalling and not wanting to idle would start again, it turned out my intake had loosened up and the cheapo intake gaskets had saturated with coolant and failed, replaced with better quality gaskets and resealed the threads going into the water jacket with the correct sealant and no problems since.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
09-30-2015, 12:29 PM | #8 |
I had a fuel pump that must have had a small hole in the diaphragm. It was just as you describe. I replace with a cheapo advance one then when I was sure it was fixed put a holley pump on it. Been running great since.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
10-01-2015, 05:46 PM | #9 |
sounds to me like it's vapor locking, is it a manual or electric fuel pump
04-24-2017, 04:00 PM | #10 |
I Just Put In 2 Sending Units And Fuel Pumps In The 2 Fuel Tanks In My 87 F I 5.7 Eng Silverardo Along With A New Fuel Filter $1600.00 Later My Truck Still Keeps Stalling When Warmed Up.
I Also Changed The Spark Plugs & Cap & Rota. And Still Stalls Out When Warmed Up, Also It Does Idle Fast When Cold The Drops Down To Normal When Warmed Up But Always Starts Right Up Any Help Here Could It Be The IAC Or Coil ??? Please Let Me Know OK Or Any Ideas Thank You All Harley03joe Last edited by Harley03joe; 04-26-2017 at 02:50 AM. |
