10-03-2015, 01:20 PM | #1 |
edelbrock carb problem
anyone else have an issue with edelbrock carbs and accelerator pump seal falling off? mine was rebuilt last year and was replaced but keeps falling off and ends up at the bottom of carb. i was wondering if maybe they had like a bad bunch of them out there that where doing this . fuel i use is less than 10% ethanol so i dont think its that.
1969 chevy c10 lwb stepside 250 6 3 ott 1971 chevy c10 lwb 250 6 with power steering 3 ott 1972 chevy k20 4x4 350/TH350 automatic 1978 chevy Malibu 4dr 305 2bbl (all original) 1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver) |
10-03-2015, 01:48 PM | #2 |
Re: edelbrock carb problem
Could be whoever rebuilt it didn't do something right. I always use edelbrock carbs never had a problem like that but then again you never know. You can call edelbrock directly or even call summit and talk to them about it
1972 gmc c15 short bed... Sold 1970 chevy custom camper patina daily driver |
10-03-2015, 04:02 PM | #3 |
Some of these carb kits now are not too good. I also think the Ethanol has some effect on them too. I had 2 of my Roch. 2G carbs do that on my 3 carb setup shortly after rebuilding them. I would check with Summit or Edelbrock & see if you can get an original pump.
10-03-2015, 10:15 PM | #4 |
I rebuilt it myself with a edelbrock kit and parts from summit. There's really not a way to mess that part up unless u install the seal upside down , but it was laying right side up when I found it. It's not possible to flip. Plus I reinstalled it correctly and it fell off a second time.
10-03-2015, 11:25 PM | #5 |
Call summit. It's probably a crap kit. They probably cheaped out on it when they made the kit.
10-03-2015, 11:25 PM | #6 |
If i remember correct the rebuild kits may have a accel pump with a seal not ment for ethanol fuel, but you can buy that pump seal seperate, I believe one is blue the other a different color.
I have never had one fall off ether.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
10-05-2015, 01:00 PM | #7 |
I had exactly that issue with an Edelbrock. When I rebuilt the carb, the accelerator pump seal that came with the kit was blue. It fell off and, just like yours, was lying at the bottom of the accelerator pump well. I had kept the old original seal, which was orange, so I put it back on. The two seals definitely have different inside diameters. I've been looking for a correct orange seal, but all I've found so far are new pump rods with the orange seal installed on it. That's probably what I'll end up buying.
