10-06-2015, 09:34 PM | #1 |
Driveshaft shortening
hello so i have a 72 c10, and i have a long bed with a 2 piece drive shaft, and I am converting it into a shortbed. i am also cutting the frame under the cab. so my question is, should i just remove the front piece of the two part drive shaft, and take it somewhere professional to have it shortened, or should i take out the entire driveshaft and get a shorter 1 piece drive shaft? thanks!
10-06-2015, 09:50 PM | #2 |
Re: Driveshaft shortening
Probably the same price either way. Your better off with a new one piece....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
10-06-2015, 09:53 PM | #3 |
The reason I say this is because my drive shaft shop won't reuse the tube .They only use the ends so they get a perfect, balanced bullet proof shaft.
10-06-2015, 10:15 PM | #4 |
ohhh okay that's smart, i didn't know if they had a machine where they could easily just shorten the tube thing on it, thanks
10-06-2015, 10:21 PM | #5 |
the boat guy
You have to take both pieces, it balanced as an assembly.
Its pretty easy to shorten a shaft, I don't know why they would need to retube the shaft. Strip the shaft, cut the weld yoke out with a lathe, cut the tube, renstall the weld yoke, time, straighten, weld, reassemble and balance. I've done it a few hundred times.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
10-06-2015, 10:30 PM | #6 | |
10-06-2015, 11:27 PM | #7 |
so you're saying that a brand new shortbed 1 piece driveshaft would be about $300?
10-06-2015, 11:34 PM | #8 |
That's what they run here. they use your yoak and ends only everything else is new
10-06-2015, 11:39 PM | #9 |
oh, i might do that then, that's way less expensive than what i was expecting
10-07-2015, 12:15 AM | #10 |
I had my two piece shaft shortened, a new rear u joint installed and balanced for $144.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO 71' Cheyenne C10 Hugger Orange on Saddle SWB Besides these two, too Many to count |
10-07-2015, 12:58 PM | #11 |
I converted my truck to a SWB.
I ended up buying a new 1 pc shaft online from Tatton Driveshaft. It was under $300 shipped. |
