10-07-2015, 11:17 AM | #1 |
Added rally wheels Beauty ring creeping or falling off?
Ok, the first day I lost two of the deep dish beauty rings that came with the rallys.
I was told to buy new ones at O'Reilly Automotive they are not as deep and nice but have stayed on for a week plus. I have one that is creeping around the wheel and I am worried it will cut the stem. I have used pliers to pull the teeth out tighter and it fits tight as hell but still is creeping. I cleaned the inside of the wheel to make sure somehow it wasnt slick but dont know what else to do as they are still creeping around and I know it will cause failure at some point on the stem. How can I stop this what should I do? Thanks PG |
10-07-2015, 12:14 PM | #2 |
Re: Added rally wheels Beauty ring creeping or falling off?
make sure your tires are balanced.... and quit hitting curbs. those curbs`ll knock your rings right off
1967custom |
10-07-2015, 12:22 PM | #3 |
I just had them mounted and balanced so I have to think they are and I promise no curbs have been the issue so far.
One the rings they wheels came with what I think is factory deep dish rings those were the ones coming off. I got the thinner aftermarket ones and one of those is the one creeping it is on the front right tire only. I guess I could swap the rings and see if for some reason that wheel is off balance? Thanks PG |
10-07-2015, 12:44 PM | #4 |
Buy a set of oem rings..even with the massive potholes in my area a gm ring has yet to fly off on me. Finding a set should not be too hard, and the can be polished to look like new as long as the lip isnt all beat.
"You can take the man out of PA, but you can't take PA out of the man" |
10-07-2015, 12:57 PM | #5 |
Are these factory type truck rally wheels and rings?
10-07-2015, 02:27 PM | #6 |
Here is an image. The wheels are factory I think 75-80 year range and the rings I have what I thought was factory those flew off and the new thinner ones that now just one is spinning on me.
Thanks PG PS: Sorry its a K5 I hope that is not a sin! |
10-07-2015, 02:39 PM | #7 |
Could just be lack of bite for the clips.
Saw one once like that, the guy put some strips of duct tape on the rim where the teeth made contact. Are those rims painted or powder coated? Powder coated is slippery! |
10-07-2015, 02:40 PM | #8 |
I dont know how they are painted but that tape is a great idea.
Odd only one wheel is doing it and I have bent the teeth in to make them super tight still spinning however. PG |
10-07-2015, 03:15 PM | #9 |
I use tape all the time, I usually use a inch roll of masking tape and wrap around the ring grippers 2 or 3 times then tap it snug with a mallet, that will/should do the trick.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
10-07-2015, 03:25 PM | #10 |
In the pic are those stock rings? They look like ones crom a camaro or corvette. The truck rings are more rounded. Not sure if that would make any difference, but the tape idea sounds good too.
10-07-2015, 07:53 PM | #11 |
Ditto!!! I did the same thing after I purchased after market rally wheels. The caps were a little loose so the guy that I bought them from suggested putting tape around the contact area. I did this and no more loose or rattling caps
Larry 1970 Chevy Pickup C-10 Dodger Blue 305CI/Th400 auto trans Long Bed/Rally Wheels |
10-07-2015, 08:39 PM | #12 |
Kinda off topic, but great looking rig!
10-07-2015, 09:11 PM | #13 |
laying low
Just a thought.
If those oversize tires sidewall flexes enough in turns to press on the edge of the trim ring it could possibly work the ring loose.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-08-2015, 04:52 AM | #14 |
The tires do not appear to be pushing the beauty rings back as I said now my only problem seems to be one the front passenger side is creeping around the rim and I am worried it will cause a failure on the stem at some point.
I am going to add tape as was suggested and see what happens. Thanks PG |
10-08-2015, 06:55 AM | #15 |
Have you tried swapping it to another wheel?
Great looking Blazer by the way.
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!! |
10-08-2015, 10:51 AM | #16 |
Wide n'Low
have one ring on the sons 75 k5 that walks, why? who knows.. Never thought about tape.. so simple and sounds like it works..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
