Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-12-2015, 05:24 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Amp going into protection mode
I have two amps. One that controls 2 eight inch subs, and 1 that controls 2 6 1/2 inch speakers and 2 6x9 speakers.
I DO NOT have a stereo deck, just RCA's plugged into the amps and then to an 2.5 mm jack that I plug into my phone.
For the last week when I plug my phone in it makes a popping sound and both amps go into protection mode. I got a new phone, but I took my old IPOD out and it did the same thing so it's not the new phone.
Any suggestions?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 10-16-2015, 10:12 PM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: Amp going into protection mode
No one?
Bryan
www.gmtruckshow.com
Old 10-17-2015, 01:19 PM   #3
shawley
Do you have full 12-14 volts with a multimeter at the amps?
Protection is normally bad ground, bad amp, bad speaker, bad fuse, etc.
If both amps are doing it, check with a meter, make sure you have full 12 volts,
If you do not, you could have a bad fuse that is partially blown.
Could easily also be a bag ground for the amp, loose ground, bad ground from battery to chassis, or a corroded ground.
My 69' C10 build thread
shawley is offline   Reply With Quote
Old 10-26-2015, 08:53 PM   #4
chuchito
As Shawley stated, check your grounds first.
How are you turning on your amps? If you have a switch to turn them on, make sure the phone is connected first before turning the amps on. If the amps are on first, you will here that popping sound as the plug goes into the phone jack.
chuchito is offline   Reply With Quote
