Need help.
1 have a 1966 suburban factory 4x4 with no engine. It has factory ac and Clam doors.
I want to put in period correct engine. Doed anyone know what to look for? ~My guess would be a 327 does anyone know the proper casting numbers? Any feedback would be great. My Vin starts K1466 |
#2 | |
Active Member
![]() Join Date: Dec 2014
Active Member
Re: Need help.
Hey Glenns66. I'm no expert, but I have a 66 4x4 Burb also. Mine currently has a 292 but I found a 66 327 I'm gonna upgrade to once I have it rebuilt. There are a couple sites. Outintheshop.com is a start. Depending on how original you want your build to be, some casting numbers were for cars and some for trucks. They were also specific to either automatic or manual tranny version pairings with engines. Post some pics of your truck. AC was a rare option. In dash or under dash version?
Posted via Mobile Device |
1961 crewcab
Re: Need help.
if I remember right , 327 was only available in the camper special 3/4 ton in 66, basically all 60-66 light duty trucks with a v8 were a 283. maybe some were special ordered with a 327 , but if that could be done , those trucks are pretty few and far between.
your best period correct engine will be the 283, 292 was available, but I wouldn't even want to try to source the air conditioning equipment for that, the sbc stuff will be hard enough.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: Need help.
Thanks guys for the info. I will keep hunting. The ac is factory in dash.
#6 | |
1961 crewcab
Re: Need help.
I still think the 283 would be the more common easier build, but maybe a 327 would work if you can find one....
Re: Need help.
fwiw i have seen period correct 6 cyl a/c compressor brackets available for the a6 compressor.
Re: Need help.
Thanks. I will be hunting for this stuff over the winter.
![]() Join Date: Aug 2013
Re: Need help.
Re: Need help.
So the things I need will be the following :
292 Any special casting # for a suburban 66 with ac? Head correct #? Any other components to look for? Thanks ahead of time for everyone's feedback |
Re: Need help.
Also guys my VIN is a little confusing. It starts with K1466....
Any ideas what that means? |
Re: Need help.
I have a complete running 283 from a 65 suburban 4 x 4
ron |
#13 |
Re: Need help.
I'm trying to put in the right motor for the year. Which is a 66 4x4 with factory ac. What would you need for the 65 if I change my mind?
#14 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Need help.
1966 was the first year with the 327 as a factory option from my research.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#15 |
Re: Need help.
#16 |
Re: Need help.
I'm confused by my VIN.
K1466F..... I can't find any that makes sense. Let's talk vaule/ resale If you own this factory 66 4x4 with ac what would you do? I've herd everthing from create, 350, period matching, BB. |
#17 | |
Re: Need help.
I don't think I've ever seen an nice original-paint 327 in a half ton truck. Has anyone else?
WANTED: * 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls. Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117 |
#18 |
Re: Need help.
Sodly, if you owned a a 66 4x4 with factory ac. But only have the frame and chassis what would you put under the hood?
292? I love to get you feedback. |
