10-21-2015, 08:36 PM | #1 |
Transfer case, posi rear end, front axle, skid plate, brackets
I converted my '72 4WD Blazer to 2WD and have these parts left over.
Transfer case $100 Shifter $100 (SOLD) Transfer case cross members with skid plate $50 (SOLD) Transfer case mount $20 Posi rear end $150 (SOLD) 4WD front axle, disc brakes, locking hubs $100 Misc. brackets, you pay shipping (Exhaust bracket only SOLD) Drive shafts also available. I live off the turnpike near Toledo airport. Last edited by Chevy Schadow; 10-28-2015 at 07:39 PM. Reason: Update |
10-21-2015, 09:29 PM | #2 |
Re: Transfer case, posi rear end, front axle, skid plate, brackets
I will take the crossmember skid plate and misc brackets if you want to ship
10-21-2015, 09:37 PM | #3 |
I assume you want the skid plate without the cross members. Let me see how much of a pain it is to get it off. It would be best if you would drive over and take everything. Worth a shot.
10-21-2015, 09:47 PM | #4 |
In line for the transfer case cross members and skid plate. That is if you decide to ship.
Paul |
10-21-2015, 09:49 PM | #5 |
LOL it is more than a drive over for me but if I was closer I would take everything off you hands. I would like the skid plate and crossmembers should unbolt fairly easy if you did the 2wd swap you should have no problem but if you would rather not ship the crossmembers than the skid plate will work. I actually only need the one bracket with the red circle if you want to sell it separately.
10-21-2015, 10:19 PM | #6 | |
Let me see if I can find an appropriate box for everything to fit in. |
10-21-2015, 10:34 PM | #7 |
Sounds good thanks
10-21-2015, 11:22 PM | #8 |
Knuckle Buster, Instructor
Would you sell just the bracket on the steering link for the steering stabilizer?
Current classic fleet: 72 K5 Blazer CST, unrestored factory Orange paint...mostly 69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration 53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue |
10-22-2015, 08:34 PM | #9 |
10-22-2015, 08:35 PM | #10 |
10-22-2015, 08:35 PM | #11 |
OK what is my total with shipping and do you use paypal
10-22-2015, 08:43 PM | #12 |
10-22-2015, 08:45 PM | #13 |
OK pm me your pp info and I will send the funds thanks
10-22-2015, 09:16 PM | #14 |
PP sent thanks
10-22-2015, 10:21 PM | #15 |
Understood, message me when you are ready if it doesn't sell together. If the distance wasn't an issue, I'd buy the complete axle.
10-24-2015, 02:44 AM | #16 |
K5drive
What's the ratio on the diff ?
10-24-2015, 06:47 AM | #17 |
I believe the ratio is 307.
10-24-2015, 12:40 PM | #18 |
K5drive
I don't suppose you would be interested in shipping the possi carrier to avoid over weight shipping fees ?
10-24-2015, 05:37 PM | #19 |
10-24-2015, 11:34 PM | #20 |
K5drive
I want to make sure The gears in my blazer are 307 . My understanding was I have 308 . Might be some rounding up going on not sure
10-25-2015, 07:32 AM | #21 | |
The posi should work with any gears. They just bolt on. |
10-25-2015, 11:12 AM | #22 |
The posi needs to be the same series carrier otherwise it won't work. 3.07/3.08 is series 3. 3.73 and 4.10 is series 4
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
10-25-2015, 09:39 PM | #23 |
If rob71 decides he doesn't want the posi and gears for the rear, I'd be interested in them as well.
10-25-2015, 10:02 PM | #24 |
Curious. What size and lug pattern of the steel rims that the axle is stting on?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
10-25-2015, 10:04 PM | #25 |
Also interested in the stabilizer hardware for both ends if it js factory. Thanks.
