Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-09-2015, 11:39 AM   #1
Rannos
Rannos's Avatar
Finally went to the track.
Took the 64 to the track last night. It did a 1.57 60 ft 6.89 1/8 at 96mph letting out about 60 to 80 ft early. Thought it did well for an iron headed pump gas sbc on a 150 shot.
Rannos is offline   Reply With Quote
Old 11-09-2015, 07:38 PM   #2
Blue Rat
Re: Finally went to the track.
That was good run. What gears?
Blue Rat is offline   Reply With Quote
Old 11-09-2015, 07:55 PM   #3
Rannos
Rannos's Avatar
Factory 3.73. Has miser axles a mini spool
Old 11-09-2015, 09:24 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
HMP ? I almost went last night . Post up a time slip
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-09-2015, 09:35 PM   #5
Rannos
Rannos's Avatar
Yeah. A few guys I been running the streets with went so I tagged along. It showed me what I need to work on. I need more gear and I have been short shifting the truck by a good bit. I'll find the time slip and post it after dinner.
Old 11-10-2015, 02:21 AM   #6
Rannos
Rannos's Avatar
This was the first time I have gone on a pro tree so I slept pretty bad. The truck did well I think for its first time at the track.
Old 11-16-2015, 02:21 AM   #7
Rannos
Rannos's Avatar
Went back tonight. Changed my tune for nitrous and truck went 1.44 60' 6.70 1/8 at 99 mph
Old 11-16-2015, 09:44 PM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
Nice passes on only a 150 shot. And a 1.44 sixty is getting it done for sure. Congrats
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 11-17-2015, 02:44 PM   #9
hotrod 80
mini truck racer
hotrod 80's Avatar
Nice 60' What did you change on the tune up .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-17-2015, 03:48 PM   #10
Rannos
Rannos's Avatar
More bottle pressure and 1/2 lbs less fuel pressure. Last week I had just under 900 in the bottle. This week I did 1050 and it hit much better.
Old 11-17-2015, 03:59 PM   #11
Rannos
Rannos's Avatar
Here is the time slip. I think there is a little more in it with tuning. I still need more gear as well. I hit 3rd at about 550 to 600ft.
Old 11-18-2015, 12:19 AM   #12
Rannos
Rannos's Avatar
Thanks. Still working on a few bugs. Once I feel I got it lined out I'll bump the kit up and see what she can do. I'd like a 6.3-6.4 once I pill it up to 250 and put more gear in it. Just put new tires on today. Was running M.T. 275 pro radials. Went to Hoosier Quick time Pro's 29x14.5
Any input on gear ratio I should look into? It's still the truck 12 bolt so I am limited on gear ratios. Am thinking of 4.56 but I do still drive the truck. Matter of fact I drove it home from the track Sunday.
