Old 11-14-2015, 04:21 PM   #1
clang6
Tie Rod Bar
Does anyone know where I can get a Tie Rod. Mine is bent and I can not find a replacement anywhere. Any help would be great.
clang6 is offline   Reply With Quote
Old 11-14-2015, 04:46 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Tie Rod Bar
Are you talking about the centerlink?
What year truck/suspension?
2wd or 4wd?
http://www.motorcityk5.com/linkage.aspx
Keith
Convert to disc brakes.
Old 11-14-2015, 05:01 PM   #3
tjsblazer
tjsblazer's Avatar
Re: Tie Rod Bar
I would post a WTB add in the parts section for 67-72 trucks. You will get the most visibility there. Just specify exactly what your looking for. I don't know if there are the same for all years.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 11-14-2015, 05:04 PM   #4
ajviper
ajviper's Avatar
Re: Tie Rod Bar
I had good look bending mine back. They are pretty stout.
ajviper is offline   Reply With Quote
Old 11-14-2015, 05:47 PM   #5
1tuff71
1tuff71's Avatar
Re: Tie Rod Bar
are you looking for a stock one or would you settle for one off a later model Chevy. I bent the heck out of mine too and went to the boneyard and picked one off a 85' 10 bolt and it bolted right up. $10 and I was good to go. The only difference was the end has only one replaceable rod end.
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
1tuff71 is offline   Reply With Quote
Old 11-14-2015, 05:50 PM   #6
clang6
Re: Tie Rod Bar
Thanks for the advice. My 69 Blazer one is pretty bent. I will see if can bend it back. I also posted that is looking for one in WTB. LMC does not carry one.
Old 11-14-2015, 06:52 PM   #7
clang6
Re: Tie Rod Bar
I would assume the 69 ones are the same as 71-72. See this one on ebay:
http://www.ebay.com/itm/New-Replacem...9WRLpl&vxp=mtr
However, it says its 52inches and I measured 50 inches. Any advice here.
Old 11-14-2015, 08:35 PM   #8
ajviper
ajviper's Avatar
Re: Tie Rod Bar
I checked my Napa interchange guide and I don't come back with a part number for a 1969 or 1970 Tie Rod. 1971 and 1972 both come back and correspond with the one you posted from ebay.
Chevy Runs Deep.
1956 210 LS1 TH350 3.31 Posi 12 Bolt
1969 Z/28 5.3 T56 3.73 Posi 12 Bolt
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2000 K2500 Suburban LS 6.0 4L80 3.73 G80
2005 K2500HD CCSB LS 6.0 4L80 4.10 G80
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
Old 11-14-2015, 09:33 PM   #9
GMC-YA68
GMC-YA68's Avatar
Re: Tie Rod Bar
Post a want to buy.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 11-15-2015, 03:58 PM   #10
1tuff71
1tuff71's Avatar
Re: Tie Rod Bar
As I said if you can live with something that's not stock another place to look is OFF-ROAD DESIGN. They have a very stout piece that is only $85 without the ends. This rod is serious beef no junk and is the route I would go if I had to do it again. These guys know their Chevy trucks too.
Old 11-15-2015, 04:05 PM   #11
1tuff71
1tuff71's Avatar
Re: Tie Rod Bar
Sorry should have do this first off.http://offroaddesign.com/catalog/HDsteeringlinkage.htm
Old 11-19-2015, 10:22 PM   #12
clang6
Re: Tie Rod Bar
Thanks. I mightl go that route.
