09-16-2003, 05:34 PM | #1 |
GO VOLS!
VIN Numbers
Does any know where I can check a VIN number online for a vehicles older than 1980? I'm looking at a blazer and have the VIN number, but carfax doesn't go back that far. Here's the VIN if any one can check it.
VIN KE180S133273 1970 K5 Blazer, looks to be a CST. Thanks.
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
09-16-2003, 06:01 PM | #2 |
K= 4WD
E= 8cyl 1= 1/2 Ton 8=??? (Recheck - should be a 6 indicating a Blazer) 0= 1970 S= St. Louis Assy Plant Number 33,273 unit built. As far as the CST goes, you should be able to tell by the trim, bumpers, nameplates on the doors, etc. (Assuming it's original). Also, on the glovebox, the code for CST is 1Z8410 "Cheyenne Equipment" Hope this helps. Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
09-16-2003, 08:08 PM | #3 |
My Blazer's VIN is:
K = 4 Wheel Drive E = 8 cylinders 1 = 1/2 ton chassis 8 = Blazer 104" WB (8 is correct for the Blazers) 0 = Last digit of the year 1970 S = St Louis assembly plant 1541XX = The 54,1xx vehicle built in that plant in that model year. My glovebox door states Custom Sport truck option, not Cheyenne. That didn't start until 1971. |
09-17-2003, 01:08 AM | #4 |
aka Crusher, Crushergmc
I've heard on some years, the "K" doesn't necessarily indicate 4wd as on the trucks. I will ask a couple of guys I know with original 2wd's if this is true. Anyone able to enlighten us on this?
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
09-17-2003, 09:02 AM | #5 |
Where's my beer?
My '72 2wd blazer has badges that say K-5 Blazer, I don't know why, I don't think it mattered if they were 2wd or 4wd, I'm guessing that it was just to set blazer's apart from pickups, but that's just a guess.
Paul How do you make the invisible, visible?.........You take it away. |
09-17-2003, 11:32 AM | #6 |
A "K" in the vin is 4wd, but all of the '69-'72 have K5 emblems on the front fenders.
Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
09-27-2003, 01:41 AM | #7 |
Workin to live...
OK, so what's the T in my VIN for, TKE182S509040, for my '72 4x4 Jimmy?
Jason |
09-27-2003, 01:55 AM | #8 |
Workin to live...
Nevermind! Found out T = GMC!
Jason |
09-27-2003, 01:13 PM | #9 |
My 72' Highlander is:
CKE182F167175 167175 ? Dose this inclued all trucks or just Blazers. How many blazers did they build in 72'? How many Highlanders? I ask a lot os questions dont I?
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
