Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 11-23-2015, 02:20 PM   #1
yardog69
solid side glass conversion- help
New to this forum. Read all the posts I found. Still need to know how to go about converting to a solid glass. Mine has 4 sliders in very poor condition. Do I need to use the frames? If I buy the gasket from Steele does the glass slip into it and then rope it in to the opening like a windshield? The lips around the quarter glass openings look too shallow for that type of installation. Can someone tell me step by step what they did and what parts they used? Thanks in advance.
yardog69 is offline   Reply With Quote
Old 02-19-2018, 12:36 AM   #2
Ehud
Re: solid side glass conversion- help
I am also in need of this information. Same thing all 4 slide but in poor condition.
Ehud is offline   Reply With Quote
Old 02-19-2018, 01:32 PM   #3
VictoriaHardware
VictoriaHardware's Avatar
For the rearward sliding windows you can get new/used glass and the repro gasket. It ropes in like you mention. None of the slider assembly is re-used.
For the forward sliders there was no factory solid glass option, so no glass is readily avaiable and no gasket either. Rearward glass & gaskets are NOT the same as the forward ones. There have been people out there who have done the solid conversion but it's all custom work.
VictoriaHardware is offline   Reply With Quote
Old 02-19-2018, 03:56 PM   #4
harryme
https://www.steelerubber.com/quarter...rip-70-1728-81
here you will get the rubber seal for the stationary windows
harryme is offline   Reply With Quote
Old 02-19-2018, 09:30 PM   #5
Ehud
Exactly what I needed!
Old 02-21-2018, 01:00 PM   #6
coolfool_2
So the same rubber and same size window glass fits the front windows if im converting to solid glass from sliders? Ive read a bunch of contradicting statements regarding this conversion. According to Steelrubber, the same gasket fits front and rear and in return, is the glass the same size?
coolfool_2 is offline   Reply With Quote
Old 02-21-2018, 01:03 PM   #7
harryme
only the rubber fits-the glass is different!
Old 02-21-2018, 01:09 PM   #8
coolfool_2
Thanks! Getting glass cut is no biggie, just couldn't figure out if there was a difference in the rubber or not.
