11-26-2015, 02:44 PM | #1 |
Run away, run far, far away from this eBay truck
http://www.ebay.com/itm/Chevrolet-C-...m=161898949926
Best I can tell, it is a c-40 and up cab. Frame has been cut. VIN looks like a 3/4 one. Just looks like a headache at any DMV.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
11-26-2015, 03:22 PM | #2 |
Old member
Re: Run away, run far, far away from this eBay truck
Just another LWB truck cut up. People do them all the time on here and sale them. How they get it through the DMV is beyond me.
11-26-2015, 03:24 PM | #3 |
The part that most alarms me is the vin has been swapped or the title doesn't match the cab. Only way to have raised pod cab lights and small rear window would be c/40-c60 cab
11-26-2015, 03:32 PM | #4 |
Old member
How many DMV people know this about these trucks? None I bet. The only thing they know is it has to match the paper work. The truck it self doesn't matter.
11-26-2015, 03:46 PM | #5 |
Thats true. Just hope someone interested in it sees this post so they know what they're getting
11-26-2015, 04:21 PM | #6 |
I have no affiliation with this sale, but the listing clearly states that the frame was cut and little/nothing about it is original. Why do you care?
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
11-26-2015, 04:28 PM | #7 |
Because the listing doesn't say anything about the cab swap and possible VIN issues
11-26-2015, 04:38 PM | #8 |
3/4 VIN, 1/2 ton axles, who knows. But he does state clearly frame has been cut. Cab clearance lights could be had on C10-30, just has to be ordered (even though the lenses on this one are mounted backward). Am curious why you state C40+ cab possibly? VIN makes it pretty clear it's a K20 cab if that VIN is from the stamped metal tag. If from the SPID, then all bets are off. Could be:
3/4 ton k20 cut to swb and 1/2 ton axles swapped in (why, I don't know) 3/4 ton cab on K10 shortened frame (that's my assumption of what happened here) SPID would help, as would actual VIN tag pic. Either way, it's a franken truck and he's up front (enough) about it in my estimate. He's not pawning it off as a Cheyenne Super, so if one wanted a shortbed K10, and had a year correct bed to stick on it, perhaps a stepside, it could end up being a pretty nice truck without a lot of money spent in the long run. This is one way to get into a k10 shortie without too much $$. I doubt this truck will sell for a very high price, especially with that bed, but it's clean enough, it runs, and it's 4wd. Great start for someone that wants to take it from there. |
11-26-2015, 05:21 PM | #9 |
The only way to have a small rear window and the raised pod cab lights is from a big truck. The column is also a patch job lending support to my assumption it is from a big truck. This post was simply to make potential buyers aware that it has more modifications than just a cut down frame
11-26-2015, 05:39 PM | #10 |
I wouldn't say its being misrepresented, but it is somewhat of a franken truck. You're right on it being a big truck cab, you can see where the wheel wells bump up into the cab floor. This is the dead give away that its a big truck cab.
Low starting bid. I don't think a potential buyer would be expecting a cream puff with this one.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
11-26-2015, 05:55 PM | #11 |
All about them K’s
I've never messed with the big trucks before but that drivers floor is sure as heck different than any of the light duty cabs I've messed with. I'd bet on a big truck cab as well. I'd stay away from this one personally.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
11-26-2015, 06:00 PM | #12 | |
11-27-2015, 12:04 AM | #13 |
I wouldn't want such a truck, but it can be titled and registered historic and no one would ever be inspecting the numbers in my state. Title work is done inside the DMV and it's all paper work. To register historic doesn't require inspection. No rust, except on that chassis that looks like it sat for 20 years, under the cab, and the floor that you could smack with a hammer and make a hole. Drive that cross country?. Better top off the leaking rear with dried out seals nd hope the calipers don't freeze up.
11-27-2015, 01:26 AM | #14 |
Like the others have already noticed its a parts truck, most likely an old farm rig that used in the latest part of its life on a medium to large parcel.
11-27-2015, 07:29 AM | #15 |
Franken truck . many states still have dot inspections and many do not have any type of inspections I have bare cabs with INTACT vin plates that were issued titles/registrations and tags here in Tn and no one ever looked at anything or ever will . In a state with no dot inspection when did you ever hear of a dot employee checking anything on any vehicle past the top of their desk ? Never happens .Up until recently you could walk in one of the small dot offices here with bill of sale written in pencil on an envelope from joe baloney and they would issue you a title
11-27-2015, 08:22 AM | #16 |
We swap cabs all day long on this site. How we handle VIN-plates is a subject not to be discussed here, but let's just say they are ways to deal with that. The laws are concerned with theft and as long as pieces to your puzzle are not from a stolen vehicle it is no more wrong than changing a fender. In the 1979 edition of the GM 47-72 10-30 parts book they describe how to deal with earlier model floor pan differences when installing a later design replacement cab that was available...use that area from damaged earlier cab.
If I wanted it, I'd buy it. Obviously, anything right or wrong with this truck is plain to see and anyone interested can make their decision knowing what they are getting into. It was a great observation to notice the cab is from a medium duty. Up to this point I didn't think that was a feasible swap, since the only pieces that are the same as a 10-30 are the back panel over the top down to the windshield posts and upper cowl (not even sure about upper cowl). The fender mounting is different and since the fenders and hood are completely different, I always thought that was too much to deal with. By the way the front outer floor panel at the kick panel is formed it leads me to believe this is a 40-60 cab. Obviously, at some point in the past, someone put a lot of work into this truck. It was probably pretty nice. So, it could have been possible either the roof or back panel was modified to create the odd combo of 69-72 top panel and 67/68 back panel. We had guys here some 10 or so years ago changing large windows to small. We've had others cut across the top behind the clearance lamps to add the pod/light area. The frame is post-72
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-27-2015 at 08:39 AM. |
11-27-2015, 11:10 AM | #17 | |
The 10 bolt axles, NP 208 transfercase and plastic/aluminum master cylinder are dead give aways to later model parts.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-27-2015, 11:34 AM | #18 |
if it sold cheap enough it would make a fun trail rig, most of them in my area aren't titled or street legal anyway
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
