Old 11-30-2015, 11:50 PM   #1
Electricduane
Door alignment - pex tubing fix
Sometimes you run across a fix or technique that seems too good to be true, or it that really wouldn't work as well as it is claimed to.
On my 89 suburban, the doors hang crookedly. The pin / bushings do need to be repaired, but they're really not that bad. The door strikers somewhere along the way lost the plastic collars that came with them from the factory.
Somewhere I read that 1/2 inch PEX tubing works really well for the collar material. I bought two feet of it for about $2 and cut out four sections about one-half inch long each. Slit each of them lengthwise, then slide them over the strikers and shut the door on each of them.
I couldn't believe it. The doors aligned pretty much perfectly and did not rattle at all. This has been driving me crazy since I bought this vehicle. I had to slam the s*** out of the doors to get them to latch, and then pretty much all of them rattled like crazy as I drove down the road.
So 1-2 feet of PEX tubing (1/2 inch size) and it will fix you right up.
Electricduane is offline   Reply With Quote
Old 12-01-2015, 03:30 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Door alignment - pex tubing fix
Someone posted that here not too far back. I can't remember who, but said he kept the leftover piece in his truck so he could give pieces to buddies w/trucks missing that bushing. I know the bushing helped the way my doors shut, I don't remember square doors shutting that nice and I was around when they were new.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-12-2015, 07:58 PM   #3
Maynard
Was just looking at the rear doors on my 1984 GMC K2500 Suburban. they're a little awry. Had the front striker bushings replaced a year ago and it did the trick, but the shop only had a pair in stock. I never got back to do the rears, having wrecked the rig shortly after.
Now that I've got it rolling again and since I've got 1/2" PEX to spare. I'll give this a try. Thanks for posting.
Maynard is offline   Reply With Quote
Old 12-16-2015, 12:13 PM   #4
elimontfort
elimontfort's Avatar
I installed these this weekend. The doors shut much better now no more slamming them. You will have to cut a slit down the side of them and slide them over the striker.
elimontfort is offline   Reply With Quote
Old 12-16-2015, 12:24 PM   #5
midnight rambler
midnight rambler's Avatar
I was able to find the right size here at work and lube it up and press it on.
midnight rambler is offline   Reply With Quote
Old 12-16-2015, 01:49 PM   #6
elimontfort
What size did you use? I grabbed some 1/2 inch and it wouldn't slide over it. E
Old 12-16-2015, 02:28 PM   #7
68Timber
68Timber's Avatar
You don't have to cut it, just remove the striker.
John
74 Honda Z50 build
Old 12-16-2015, 03:31 PM   #8
midnight rambler
not sure of the size, found it here at work. I did use my hand press and some lube as it was a tight fit, I did remove the striker.
Old 12-16-2015, 07:06 PM   #9
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Do not cut the tubing. As mentioned, unbolt the striker and slide the tubing over it.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 12-16-2015, 08:54 PM   #10
zaccaglin
zaccaglin's Avatar
What's wrong with cutting the tubing? I've had to o let do this fix twice in the 4 years I've owned my sub.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
Old 12-17-2015, 01:13 PM   #11
elimontfort
Yeah what's wrong with cutting the tube? Electricduane even mentioned it in his post.
Old 12-17-2015, 01:22 PM   #12
68Timber
68Timber's Avatar
Well, it's plastic and wears out and falls off. I'm guessing being cut from one end to the other will only speed that up considerably. If you don't mind that, no biggie. But it's not a big deal to remove the striker and slide the pex on without cutting it. Honestly it probably doesn't take any longer to do it that way either. Just use a pencil to make some reference marks around the washer, then you can tighten it back down exactly where it was.
John
74 Honda Z50 build
Old 12-17-2015, 01:41 PM   #13
Electricduane
I slit the pex tubing and put it on that way. . . mostly out of laziness. That, and it's possible (I have a burb) that the "nut" (backing plate) can break loose if I remove the striker . . and fall down into the door sill.
No doubt removing the striker is a better method. . . but the pex seems to be lasting just fine, slit and all. The plastic collars on the OEM strikers obviously fails after a period of time. . . the pex tubing will as well, probably sooner with the slit. . . but if it lasts a year or 2 with the slit, good enough for me. . if I get bored, I will prob try to remove the strikers and do it the "right" way. . .
Old 12-17-2015, 07:48 PM   #14
68Timber
68Timber's Avatar
That's a legitimate concern, one of the captured nuts that holds my hardtop to the bedrails on my 79 escaped, so I've got that to deal with when it goes to paint. I hosed my strikers with penetrating oil the day before I did this, but I don't know how much (if any) got through to the threads. Sometimes you just have to cross your fingers and hope you're not about to fudge it up.
John
74 Honda Z50 build
Old 12-28-2015, 11:51 PM   #15
USSkoval
I never remove my strikers anymore, it seems half of the time the caged nut is no longer caged. That can make for a not so fun day.
Slicing the pex tubing doesn't hurt it. As long as the door is adjusted correctly, it will last for years, even on a daily driver.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 01-01-2016, 12:56 PM   #16
Nodnarb76
Nodnarb76's Avatar
Is this the right tubing?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 01-01-2016, 01:05 PM   #17
Electricduane
Yep, that is it.
Old 01-01-2016, 05:41 PM   #18
68Timber
68Timber's Avatar
FWIW, I saw these striker bushings for sale in Autozone the other day, they were in the Help section and were inexpensive. Then you get the correct color. If that bothers you.
John
74 Honda Z50 build
Old 01-06-2016, 11:17 PM   #19
USSkoval
Pex is available in white too.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'88 K20 Suburban
Old 01-20-2016, 10:43 AM   #20
MalibuSSwagon
The PEX I got is white. It was a couple bucks for an 8 ft section at Lowes, so I've been giving away pieces to friends to fix their doors.
MalibuSSwagon is offline   Reply With Quote
Old 01-22-2016, 03:03 PM   #21
WarBeard
WarBeard's Avatar
I always used electrical tape.....Pex tubing is far less Redneck! Good idea.
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
