12-02-2015, 08:09 PM | #1 |
duramax stumbling
have a 05 3500 4x4 and driving along the truck starts to stumble if feeding it fuel and then shuts down in the limp mode. I then hit the brake to stop and the truck returns to normal except check engine light stays on and runs fine for a while and then starts it all over again. Chevy dealer a while back found a chafed wire going to the fuel injector regulator and repaired and it was going great and then started acting up again, back to the dealer to check previous repair and everything was okay, they have tried a bunch of things but haven't found anything else, hoping some one has heard of this or experienced the same and can tell me what was done to solve it.
thanks
2020 GMC Acadia Denali (Maroon) 2003 GMC 3500 4X4 Dually Dump (Red) 2007 KZ 41KG Toy Hauler (White with stripes) 2015 Harley FLHTCUTG Trike ( Maroon) 1995 Harley FLT (2 tone Red) 1992 Chevy S-10 4x4 Blazer (Dark Red) |
12-05-2015, 12:05 AM | #2 |
Re: duramax stumbling
What are the Codes??
12-05-2015, 05:30 AM | #3 |
there was only one code and the dealership didn't furnish that to me
12-05-2015, 09:34 AM | #4 |
Go by your llocal parts store they should be able pull the codes
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-05-2015, 11:35 AM | #5 |
dealership still has truck and they are now tracing the wire back from the previous repair to see if it has another bad spot as that is what the GM techs at factory say to do as they have seen this before, I hope they find it as it sure doesn't give a person a good feeling about driving anywhere especially it the winter months
12-13-2015, 08:10 PM | #6 |
more on having trouble with my 05 6.6 with the PO090 code and no start. dealer fixed frayed wire one that went from the FICM to Regulator and the problem seemed to go away. 1 month later the same problem with the same code, dealer could find nothing wrong the placed a call to TAC, they recommended that restring new wire from FICM to Regulator which they did and it seemed fine no more code. let it set for 2 days and went to go Christmas shopping this morning and a no start problem again, had neighbor come over with code scanner and low and be hold the Code PO090 shows up again, this has cost me almost $800 so far and I need an answer can anyone help?? thanks
12-13-2015, 10:43 PM | #7 | |
The Fuel Pressure Regulator (FPR) is not wired to the Fuel Injection Control Module (FICM), It is wired to the Engine Control Module (ECM). Has the FPR been replaced? While LLY Duramax wiring issues are very common, A intermittent P0090 can also be the FPR itself. You cannot run either of the FPR control wire over any Injector Control Wires! They have to be shielded from electrical interference with a bare ground circuit. Diagram... |
02-09-2016, 08:25 PM | #8 |
finally found the cause of the PO090 code. it seems that a ground that is some place was corroded and so far it has work correctly and I am knocking on wood that the bug is dead never to rear its ugly head again
