![]() Join Date: Mar 2014
My 63 SWB BBW Build Frank
So since I'm done (for now) with my 63 Stepper "EZ Eight" and my 70 C10 is now a citizen of Australia
![]() Here's Frank sitting next to EZ Eight and starting to get piled in... ![]() And here's my former 70 C10 that now resides in Australia ![]() Last edited by NVS-C10; 12-15-2015 at 04:03 PM. |
Re: My 63 SWB BBW Build Frank
So got Frank out and have another project to keep EZ Eight company lol...
So now that Frank is in a place where I can work on him, I dusted him off and checked out where I left off and what's next on the list. I also installed some freshly powder coated stockers and new rubber.
![]() I had already finished most the front suspension and my next steps should be rear suspension then the 283/Powerglide drive train. ![]() Last edited by NVS-C10; 12-15-2015 at 09:17 PM. |
Looks good, I'll follow along.
Post Whore
![]() Join Date: Mar 2013
In for the build. Frank is a good looking truck!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
I do like the EZ-Eight truck.
If it and the Australian are anything to go by..... Frank will Frankly be terrific.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
OK some updates...
Got my CPP notches in (you can see the template I made on the floor in the background: ![]() Shipping was free and super-fast (1-day), fitment was spot on, and the only hard part of the job I could say was getting out (fighting lol) the factory rivets ![]() |
Next was on to the rear shock relocation brackets...
Drill and bolt in...
![]() They line up good with the frame and fit nice next to the CPP notches... you can also see the CPP Deluxe Trac Bar installed with 2" CPP Drop Blocks. ![]() ![]() |
I'm using the factory bottom rear shock mounts just flipped around and swapped sides...
![]() Frame clearance is good... ![]() Here is the hardware for the top shock mount to bracket... ![]() |
Best part is the shock angle looks really good so they should function the best they can...
#13 |
Post Whore
Looks good!
#14 |
#15 |
Well I worked on a few different items but kind of bounced back and forth between; not fully finishing any one item.
I got the engine and trans in but still need to bolt on some more items and then will post pics. I also started on the bed floor but wasn't able to finish with the holidays.. will post pics when complete. So not to leave you without any pics; here's one I took on Sunday of the rear sitting a hair above driving height. The front is static drop and the rear will be bagged (currently the rear is blocked up to estimated ride height). ![]() Last edited by NVS-C10; 01-05-2016 at 08:57 PM. |
#16 |
Nice!!
You can find me on Instagram @neveno_cten |
#17 |
![]() Join Date: Oct 2009
subscribed… really like where you and Frank are going.
#18 |
#19 |
#20 | |
Thanks!! Do it they are only young once!!
#21 |
#22 |
Been a few weeks since I updated but still been working on Frank..
Got 2/3's of the bed done.. will finish back half after I get my tank and compressor mounted (its going under that part of the bed). ![]() Last edited by NVS-C10; 02-08-2016 at 03:13 PM. |
#23 |
Got motor and trans in..
![]() I used the CPP Trans crossmember and it worked great with my Powerglide; and I can use the same crossmember and mount if I want to upgrade to 700R4 later on. ![]() ![]() |
#24 |
Also since this chassis was originally fitted with a 3-Speed Manual Trans, I had to find an original Powerglide frame pivot bracket (that was a search lol).
![]() I setup the starter for a remote starter solenoid and added a large 4-gauge ground strap for increased engine and starter grounding. ![]() |
#25 |
Lastly I cleaned up the cab for installation next weekend!!!! Can't wait!
