12-16-2015, 10:33 AM | #1 |
1972 Blazer has A/C but SPID does not show it
Hey guys, question for the ones that might know. Did the dealers ever install A/C but not have it listed on the SPID? Have a 1972 project Blazer that has A/C but does not show it on the SPID. VIN plates match the SPID vin. Ever seen this?
12-16-2015, 12:29 PM | #2 |
Re: 1972 Blazer has A/C but SPID does not show it
Probably added by a PO. Check your firewall if it's been altered. Check this link and it shows the difference in AC VS non-AC firewalls. If yours originally didn't have AC then the firewall would have had to be cut. Another place you could check is the side AC outlets. If it's factory, then the edge of the holes would be die cut. If it was installed afterwards then the edges would most likely be rough and not symmetrical.
http://67-72chevytrucks.com/vboard/s...d.php?t=471215 |
12-16-2015, 12:36 PM | #3 |
Thanks for the link. Will take a look at that tomorrow.
12-16-2015, 01:02 PM | #4 |
The only pic I have of the engine bay right now is this one. Not sure if it gives you enough to see anything that is in the wrong place.
Anything look wrong or different? https://www.facebook.com/photo.php?f...type=3&theater |
12-16-2015, 01:10 PM | #5 | |
The question I thought you were going to ask was "could the vehicle have been built with A/C but not be on the SPID?". I would say "no" to that as well, since the same database drove the build information and what was printed on the SPID. Some stand alone RPOs are easy to add extemporaneously (like a trailer hitch) but A/C is too integrated to try to add on the fly. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-16-2015, 01:54 PM | #6 | |
Member #1049
12-16-2015, 02:22 PM | #7 |
I noticed that it did not have a bolt there as well. hmm Wonder how hard that will be to get up and running. Just bought this thing. Here is a picture of the dash that looks like a original uncut A/C dash. See anything weird about it?
12-16-2015, 05:32 PM | #8 |
Last link didn't work for me.
12-16-2015, 06:09 PM | #9 |
Try this one. https://www.facebook.com/jon.mills.9...26515804037532
12-19-2015, 08:13 PM | #10 |
I'm probably wrong but the only a/c I know added after the factory is added under the dash and has like a sort of horizontal unit under the heater face.
12-20-2015, 08:58 PM | #11 |
I think you are right. Had a chance to look it over. Someone before my tried to add A/C but never finished it. I have 3 extra full sets of A/C units so will have to figure out what I am needing and steal from those.
