12-24-2015, 12:55 PM | #1 |
late model 16" wheels fit C20?
Anyone know if "modern" (1989-2000?) Chev. 2500 pickup stock steel wheels 16X6.5bolt pattern (8 lug) will fit my 1971 (disc brake) C20? Thanks
12-24-2015, 01:00 PM | #2 |
Re: late model 16" wheels fit C20?
Sweet another Orland, CA member
Yes those wheels will fit. No problem on my 72 C20 with disk brakes. |
12-24-2015, 10:57 PM | #3 |
Yes they do fit but the offset is a little different on the newer wheels and they are tucked in a little more. Lots of guys use some spacers to make the wheels move outward other it doesn't bother. There is also a guy on E-bay that sell lug nuts with the outside threads to screw the hub caps on and keep the original lug studs. His name is lug nut king.
12-24-2015, 11:39 PM | #4 |
these?
12-25-2015, 01:53 AM | #5 |
12-25-2015, 09:15 AM | #6 |
12-25-2015, 09:37 AM | #7 |
12-25-2015, 02:25 PM | #8 |
I know 17" Hummer H2 3/4T wheels fit a C2500, which is about the same question, and clear the factory discs. Backspacing might be different but I couldn't tell. I used spacers in the rear to clear the Dana60 hubs - that's going to be a challenge for any hubcap or cover you choose to run.
