Old 12-24-2015, 02:57 PM   #1
davepl
davepl's Avatar
Two fuel senders in series
I was just thinking, since fuel level senders are ohm (resistance) based and higher ohms means more fuel, couldn't you in theory run the senders all in series, and it'd tell you what the total level of all three tanks was? If you had two half tanks, it'd read full. A quarter and an empty would read the quarter.
When all were full you'd have 270ohms and the gauge would read about 1/4 way past full, based on seeing it open in the past.
I imagine people either only monitor the main tank or, if fancy, have their switch also switch which sender to read. But on paper it'd seem to work.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-24-2015, 11:10 PM   #2
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Re: Two fuel senders in series
Your gauge should read 0-90 ohms. 90 being full. A dash mounted switch would be your easiest option. The senders in series would not work like you are suggesting without damaging your gauge. GM did use a module on the 3500HD trucks to average both tanks and send the correct value to the gauge. One could probably be used to do the same for your truck. It was only a 2 tank system tho.
Current classic fleet:
72 K5 Blazer CST, unrestored factory Orange paint...mostly
69 C10 factory SWB, 454, TH400, Saddle tan, Rust-o-ration
53 Studebaker M35 w/331 Reo gas I-6, Air Force Strata Blue
dutchmanz is offline   Reply With Quote
