Old 12-24-2015, 06:55 PM   #1
NCBowtie
72 Gas Tank Source?
I'm looking for a 72 gas tank. I seem to only be able to find the older style tanks that have EEC. The 72 tank has a smaller diameter filler neck. It also uses a different gas cap and grommet. Does anyone know where I can find one?
NCBowtie is offline   Reply With Quote
Old 12-24-2015, 07:30 PM   #2
70cst
70cst's Avatar
Re: 72 Gas Tank Source?
I would post a WTB in the parts forum - you should be able to locate one. Good Luck
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 12-24-2015, 11:03 PM   #3
PepperTreeGarage
PepperTreeGarage's Avatar
Lmc
PepperTreeGarage is offline   Reply With Quote
Old 12-24-2015, 11:10 PM   #4
NCBowtie
As far as I know, all the LMC tanks are 67-71 style.
Old 12-25-2015, 01:10 AM   #5
In The Ten Ring
I agree with the poster above, check the parts forum and maybe look at CL for trucks being parted out.
Now if you find one, it might have rust on the inside. Mine did. I took it to a radiator shop and had the clean it out and "renew" it on the inside with a sprayed in liner. I haven't tried it yet but I did put it back in. I had to make all new supply lines. I used Krud Kutter to clean out the inside of the vent lines.
In The Ten Ring is offline   Reply With Quote
Old 12-25-2015, 01:18 AM   #6
57taskforce
All about them K’s
57taskforce's Avatar
Shame your so far away, I've got a 72 1/2 ton Eec tank I'd give you for free...
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
