Vent tube rebuild
So I opened up my vent tube to rebuild in SS and the center line goes to the very top where as the outter ones just penetrate the bottom plate. Does anyone know the purpose/where they should be plumbed?
#2 | |
The Older Generation
Re: Vent tube rebuild
LockDoc
The vent tube by the filler tunnel on the inside driver quarter.
#4 | ||
I will wait until I know what year your truck is before posting more. LockDoc
I assumed its the same for 67-72? I have a 71 K10 Suburban. Also since I have your attention I'm going to hijack my own thread. I just pulled my tailgate lock out and there is no code and your thread said to contact you if so.
#6 | |
There is a difference in the years because the '71 & '72s have the charcoal canister and evap system for the emissions stuff. That is what the extra tubes are for. The '67-'69s don't have that. (except for maybe in California) That is why it is important to give all the information you can on your truck when you post questions.... If all of your emissions stuff has been removed that would be why the outer tubes don't go anywhere. I will PM you my info. LockDoc
The tubes dont go anywhere because I replaced the fuel lines except for there because I swapped to diesel and I forgot where they go. So then I dont need the vapor tube? I just need to vent the tank?
#8 | |
LockDoc
The tube inside the truck is a fuel separator. It's purpose is to prevent liquid gasoline from getting to the evap canister. Newer vehicles put a dome on the top of tank which eliminated the need for the separator.
You should not have any need with a diesel.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Okay well if anyone is in need of a new vapor tube, I was in contact with a company that can do the vacuum brazing to make it factory original, or I can make them differently that still functions as factor .
