Old 01-26-2016, 10:37 AM   #1
jmillsUT28
Will not stay in park on a incline. Popping sound from trans
Restoring this 72 blazer and when I park on a incline with the front downhill it will not stay in park. This is a auto transmission. When it moves in park the gear selector at the steering wheel does not move but you do here a clicking noise from the trans. It does not do this when parked on a hill with the rear downhill. Just when the front is downhill.
The bushing on the shift linkage coming down from the steering column is a little worn but does not seem to be casing this problem.
Could this be a internal problem with the trans? Any other options?
Thanks for the help like always
jmillsUT28 is offline   Reply With Quote
Old 01-26-2016, 11:32 AM   #2
Bigdav160
Bigdav160's Avatar
Re: Will not stay in park on a incline. Popping sound from trans
It sounds like the parking paw int the transmission is worn. You should be able to determine this by removing the pan.
In this example the rod that moves the paw is damaged
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-26-2016, 11:33 AM   #3
jmillsUT28
Perfect. Will take the pan off now and see what I can find. Any idea where I can buy that paw at?
Old 01-26-2016, 01:20 PM   #4
Bigdav160
Bigdav160's Avatar
The paw is difficult to replace. The shaft the paw pivots on is in a blind hole. The pivot shaft is installed/removed on the exterior of the case under a small freeze plug.
Removing the freeze plug and coaxing the shaft out is frustrating. I've only ever done two. There's also a return spring the has to be installed correctly.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 01-26-2016, 01:48 PM   #5
jmillsUT28
Here are some pictures. From what I can see and looking at a picture of a new pawl online that mine looks to be in good condition.
[IMG][/IMG]
Below are two other pictures. The parking lock bracket does look like it is warn down a little but is this enough to cause it to slip?
[IMG][/IMG]
[IMG][/IMG]
Old 01-26-2016, 06:27 PM   #6
jmillsUT28
Update for anyone that might run into this problem. The pawl as in the picture has two machined areas in it from the factory. Might look worn but it is not. The bracket that I have shown in the second picture holds the pawl in place. As you see in this picture it is worn and missing some material. I cleaned the bracket and then welded new material then used a grinder to smooth it out. I also noticed that the area where the two bolt holes are were bent a little. I flatted this out.
Problem fixed. Will stay in pack on a include and not move.
