Old 01-31-2016, 12:03 PM   #1
72GREENC10
72GREENC10's Avatar
1972 C10 Pro Touring/Autocross build
Hey guys, ive had this truck in my family for the past 18-19 years and was given to me as a highschool ride when i was 15. needless to say, i put it through hell for those few years, after highschool i drove it to work for a few years and finally bought a daily. then this year i had enough to get the it built how i always wanted. So i thought id share this with you guys, Yes i know its a longbed, yes its a leafspring truck, but that doesnt show itself as a problem, i see it as a challenge that would be fun to take on. so ill be keeping you guys updated for a while from suspension, steering, drive train, and paint.
I decided to go with cpp for the front suspension, i liked their products, as well as the customer service and the cost of their stuff, so i bought upper and lower control arms, tie rods, steering box, spindles,sway bars, springs, and some other small things, needless to say, everything installed super easy, and i love it,couldnt be more happy.
As far as brakes go, i went wilwood d52 kit for the front for the time being. im planning on having the d154 kit for the rear as well soon. got the pads bedded yesturday and wow i am amazed with the product as well as simplicity. the brake lines were a struggle to figure out because of the different sizes on the hard lines coming down to the cross member but i got it figured out. stops great.
Steering, i went simple, quick ratio box from cpp, installed it yesurday, and wow i am completely amazed in the difference, these guys know their stuff, if your not looking to get into a rack and pinion this is the next best thing. super stiff feeling, no slop and very good ratio.
shocks, easy for me, ridetech, hearing nothing but good about their hq series shocks, still waiting for those to come in, should be fairly soon.
wheels and tires, i wanted something cheaper, but can still take the beating, so i went with rocket booster wheels wrapped in potenza re11 tires, the look awesome and werent priced super crazy. love them.
ill keep you guys updated when i get my shocks and the rear sway bar in.
72GREENC10 is offline   Reply With Quote
Old 01-31-2016, 12:06 PM   #2
72GREENC10
72GREENC10's Avatar
Re: 1972 C10 Pro Touring/Autocross build
got it aligned and put the steering box in
Old 01-31-2016, 12:11 PM   #3
72GREENC10
72GREENC10's Avatar
Old 01-31-2016, 01:45 PM   #4
'68 Newtricks
'68 Newtricks's Avatar
nice, how much drop is that in front?
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 01-31-2016, 01:48 PM   #5
72GREENC10
72GREENC10's Avatar
3 1/2
Old 01-31-2016, 03:50 PM   #6
knomadd
knomadd's Avatar
Looks good with those wheels. Nice choice!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 02-03-2016, 09:39 PM   #7
72GREENC10
72GREENC10's Avatar
Still waiting on my shocks and rear sway bar 😑 ordering my rear brakes Friday and I got my gorilla lugs today!
Old 02-03-2016, 09:45 PM   #8
72GREENC10
72GREENC10's Avatar
My lady
Old 02-03-2016, 10:44 PM   #9
Raleighswb
Originally Posted by 72GREENC10 View Post
My lady
Looking good,what are the specs on the wheels and tires?
Raleighswb is offline   Reply With Quote
Old 02-03-2016, 10:47 PM   #10
72GREENC10
72GREENC10's Avatar
Wheels: Rocket booster 18x9 5.25 bs
Tires: 275 40 18
Old 02-09-2016, 09:03 PM   #11
72GREENC10
72GREENC10's Avatar
Got my rear brakes in along with proportioning valve, lines and fluid.
Old 02-10-2016, 11:01 AM   #12
BossHogg69
motor exploder
BossHogg69's Avatar
You've got some very nice hardware going into this build - and daring to be different with the lwb pro-tourer. I'll be keeping an eye on this build.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 02-11-2016, 12:49 PM   #13
knomadd
knomadd's Avatar
I remember those boxes. Brings back memories of my install. You'll love the look when you're done!
-Duane
Old 02-13-2016, 09:36 AM   #14
72GREENC10
72GREENC10's Avatar
Got my shocks in, and installed, I am very impressed. Love them!
Old 02-13-2016, 09:38 AM   #15
72GREENC10
72GREENC10's Avatar
Truck handles amazingly!
Old 02-14-2016, 05:42 PM   #16
72GREENC10
72GREENC10's Avatar
Went and finally put the suspension to work and it was awesome. posi and rear sway bar next.
Old 02-26-2016, 01:10 PM   #17
72GREENC10
72GREENC10's Avatar
Finally got my trutrac. Gearing is the next obstacle, I'll be running a 400hp sbc with a 700r4 on a 18" wheel with a 40 series tire of anyone has recommendations. I decided to pull the old 350/th350 this weekend and to start degreasing and undercoating the frame and under the body. The rear end is going off to get the ring and pinion installed soon. I will more than likely be running the stock axles seeing that I won't be making any crazy hp. I also got my shock brackets for the front from cpp.
Old 02-26-2016, 11:26 PM   #18
1971_c10
1971_c10's Avatar
I have ~380 hp SBC with a 700R4 in my '71 stepside. I have 3.73 gears in the rear end w/ ~27" tire. With the tall 1st of the 700R4, you probably don't want too steep of a rear gear. With the 3.73, I'm out of first ~15-20 mph under normal acceleration. Under full throttle, you'll probably be out of 1st by ~35-40 mph depending on how high you let the motor rev. I'm toying around changing the rear end out, and I would still stay with ~3.70 gear. There are some shops that will put a shorter 1st gear in the 700R4 to get the 1-2 shift closer together. Good luck with it all. I'm jealous of the tru-trac. Curious how it goes in with the C-clips (I'm assuming you still have the c-clip axles).
1971_c10 is offline   Reply With Quote
Old 02-28-2016, 02:44 PM   #19
72GREENC10
72GREENC10's Avatar
The truck will be autocossed regularly and will still be driven on the street on the weekends. so I need all of the quick acceleration I can get, so a 3.73 might be what I end up getting. It will have a fuel injected sbc pushing about 430hp, Should see around 58-6k rpm. It also has a 26in tall tire. And I've heard good things about the trutrac so I'm excited to get it put in.
Old 02-28-2016, 10:32 PM   #20
1971_c10
1971_c10's Avatar
72greenc10, I plugged your #'s into one of my spreadsheet calculators to give you some expected shift speeds based on a 5800 RPM shift point w/ 3:73:1 rear gears (using the stock 700R4 gear ratios and using a 275/40/18 which is ~26" "squished/loaded"). 1st - 39 mph, 2nd - 73 mph, 3rd - 119 mph, 4th - 170 mph. Those are of course theoretical speeds assuming no slip in the drivetrain. Generally, the calculator hits 1st and 2nd pretty good, but then drag effects starts to kick in and you start wishing you had more HP . If you want to see any different rear end ratios just let me know and I can run them through my calculator or give you some equations you can use on your own.
On a side note, I too am working to make my truck more "pro-touring/autocross", although flipped flopped from you, more driver than racing. I'll definitely be following along on your progress. Haven't decided on my suspension just yet though. One day I'll start a build thread ...
Old 02-29-2016, 12:17 AM   #21
72GREENC10
72GREENC10's Avatar
Awesome thank you for the help. I'm keeping that info for when I get my gears. As far as suspension goes, if you have any questions on stuff I am using feel free to ask, I'd be more than happy to help you, this Friday I am ordering my trailing arms and I am ditching the leafs.
Old 02-29-2016, 12:34 AM   #22
72GREENC10
72GREENC10's Avatar
The truck will be getting torn apart this week to paint the whole bottom side of the truck. I put too much much time and money to leave it covered in grease and oil, clean makes the job easier in my opinion, especially when making repairs and adjustments to the truck. So I will be degreasing everything then taking a wire wheel to the underside of the truck, then paint, then assembly. I already got the trans and drive shafts out. They are getting sold. My goals for now are to get the trailing arms put on the truck, shocks relocated, trutrac and gears installed, fuel tank installed and go from there. I also took my 18's off and put my old steel wheels back on while it's getting torn apart and painted.
Old 03-21-2016, 12:09 PM   #23
1971_c10
1971_c10's Avatar
Hey man, how's things going? You tear into the rear end yet to toss the true trac in? Hope all is well.
Chris
Build Thread for my '71 Pro-Touring: http://67-72chevytrucks.com/vboard/s...d.php?t=722029
My C10 has it's own facebook page! www.facebook.com/c10cj - it is a public page so no facebook account required to browse through.
Old 04-03-2016, 05:55 PM   #24
72GREENC10
72GREENC10's Avatar
Hey guys sorry I've been busy messing with the front end trying to get the alignment correct, I got early classic trailing arms, adjustable trailing arm brackets and hotchkis springs front and back. Just waiting on two more retainers for the rear springs. As for the tru trac that's coming up next, thanks guys!
Old 04-03-2016, 10:09 PM   #25
1971_c10
1971_c10's Avatar
Great to hear you are still making progress!! Keep it up!
Chris
