Old 02-05-2016, 06:32 PM   #1
crazy longhorn
Fabricate till you "puke"
02 silverado,heater motor/relay
I have been seeing the fan speed does not work in the lower ranges, & figured that the relay was going.....well, she quit,(no fan @ any speed) with cloud of smoke under the dash & out the vents! The question that I need to ask, is did I smoke some wiring also? Electrical, is not my best subject....any help, would be very helpful. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-06-2016, 11:04 AM   #2
gmclowsierra
Re: 02 silverado,heater motor/relay
more than likely the resistor burnt up. that is a own problem with those. the harness probably is burnt as well. you can get the new resistor and plug from your local dealer. the plug is a pigtail with about 12 inches of wire to get rid of the burnt part. the fuse might have blown as well.
gmclowsierra is offline   Reply With Quote
Old 02-06-2016, 07:10 PM   #3
crazy longhorn
Many thanks bro trucker....the resistor, is fryed. The plug looks, but I will unwrap the wires to check for the melt down Longhorn
Old 02-08-2016, 04:25 PM   #4
gmclowsierra
I wouldn't trust the plug. just change it and be done with it.
Old 02-10-2016, 12:12 AM   #5
crazy longhorn
Thanks again I thought I had the resistor, from a parts truck....got the blower motor, & the end of the harness. yes , a couple wires close to the plug have been heated! Orilleys offers a Dorman resistor & plug pigtail for about 42 bones.....good deal, or would you go AC delco? longhorn
Old 02-10-2016, 06:23 PM   #6
68C15
blood type; Retumbo
68C15's Avatar
F*** Dorman!!! If it's metal, rubber or plastic it is junk.
I find the blower starts drawing high current loads (not high enough to blow fuse) and takes out resistors and pigtails.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-11-2016, 07:13 PM   #7
Flying Hamster
Flying Hamster's Avatar
Dorman resistor and pigtail will work, IF you get the right one. There are several different configurations.
G.M. put the resistors in the case so airflow will cool them, but they are at the low spot in the blower case. Water build-up in the case will destroy the resistor. Also, the plug is where everyone on the passenger side can kick it...
Makes me wonder of they were hiring cast-off Ford engineers...
Flying Hamster is offline   Reply With Quote
Old 02-11-2016, 10:09 PM   #8
crazy longhorn
Show me the right confirguation, on the dorman resistor? I do not want to spend 3 times on the Delco part....if I do not need to Longhorn
Old 02-14-2016, 11:31 AM   #9
Flying Hamster
There are different applications depending on wether it's got climate control, Manual control, and stuff like that. If you go to autozone's website, you should be able to get the right part#. (then buy it on amazon for 1/3 the cost!)
Old 02-19-2016, 04:07 AM   #10
crazy longhorn
Thanks again guys....I got the delco parts from the dealer (sons discount) longhorn
Old 02-23-2016, 12:45 AM   #11
crazy longhorn
Update guys....the blower was also smoked! I had a spare,from a parts truck, that just keeps giving crazy L
