02-11-2016, 04:53 AM | #1 |
66 C10 with original Drum Brakes and Power Booster ?
Hello,
I have a 1966 C10 with the 283 V8 and the 3 on the tree tranny. I have a new Master Brake Zylinder linke the Picture. I Have the original Drum Brakes all around. Now my Question. Is it a good Idea to put a Power Booster (picture 2) behind the Master Zylinder to get a better Brake force ? Must a change something else ? Also a have bought a new brake line set. Thank you all Greetings from Germany Nils |
02-11-2016, 09:02 AM | #2 |
Re: 66 C10 with original Drum Brakes and Power Booster ?
I would suggest splitting the brakes and upgrade to a dual pot master cylinder while you are updating to use the power booster.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab |
02-11-2016, 11:55 AM | #3 |
Yup first thing to swap is that master cylinder. If you go to Captnfabs thread in the for sale section for his bracket there is a list of what you will need to get for a booster and master for the drums. This is one of the best things you can do to improve the safety of you truck. There is a thread in the FAQ section on splitting the system.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-12-2016, 05:49 AM | #4 |
Thank you verry much Jimmy,
I have send Captnfabs a PM. I think about it and would now change the Master Zylinder and but a Booster on. Some Master Brake / Booster Combos are only for Disc/ Drum or Disc/ Disc or Drum/ Drum. What are the differents ? I searched and a found the Set from CPP (6366BB2-9). Can a use this with my 4xDrum Brakes ? Can i use this Set if I change in the Future to Disc Brakes ? Thank you all verry much. Nils |
02-12-2016, 09:57 AM | #5 |
I have a factory drum booster I will sell for 50.00 if you are interested, for drum, drum.
02-13-2016, 06:10 PM | #6 |
I just bought a running and driving 1964 c/10 with boosted drums. It still has the single master cyl and stops great. With that being said I don't like the fact there is no backup plan, if I blow a wheel cylinder on any corner I will be without brakes. Hope this helps and good luck on your project!
02-14-2016, 12:19 PM | #7 |
Will a 67 dual reservoir fit our 66 dual drum at the firewall? I'd like to at least split the fronts and rears...does it need a valve as well? And who makes the best brake line clips..tried to save my originals but they got a little squished up!
02-14-2016, 12:26 PM | #8 |
This is what I followed when I did my 65: http://67-72chevytrucks.com/vboard/s...d.php?t=332148
However, I used the 67 truck M/C instead of the Impala and it works just fine. Bolted up with no modifications to the push rod. I did not use a proportioning valve. From Rockauto.com: http://www.rockauto.com/en/catalog/c...+cylinder,1836
02-17-2016, 03:51 PM | #9 | |
how does the brakes feel with no proportioning valve? |
02-17-2016, 05:55 PM | #10 |
The brakes seem to work just fine to me. Solid pedal feel, and unless I stand on it, they stop without any lockups. I have been running it like this for over a year now.
02-17-2016, 06:55 PM | #11 | |
Making other changes (like swapping to front disc brakes) is a different story though. |
06-07-2016, 09:12 PM | #12 |
But Found Her 25yrs Later!
Regarding the stock drum/drum brake booster :
Does the stock drum brake booster mount right up to the firewall without any modifications? Does the stock booster pushrod mount right up to the brake pedal without any modifications?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
06-07-2016, 11:55 PM | #13 |
60-66 Nut
There are a couple of different stock brake boosters. They all had some sort of mounting bracket and or wedge to mount them to the firewall as well as directly to the pedal bracket on the inside of the firewall. This ensures a good solid connection between the brake pedal, the bracket it swings from and the booster/master combo.
01-22-2022, 11:48 PM | #14 |
